L8 ecu in 2wd cossie?
Old 24-01-2008, 12:56 PM
tommeke
tommeke's Avatar
Default L8 ecu in 2wd cossie?
hello,
Is it possible to put a L8 ecu in a 2wd sierra cosworth 3dr?
now the car have a L6 stage 3 ecu bij MSD
but I want to put the new MSD software in with closed loop, anti lag and maybe launch control...
Is it posible to put the L8 ecu on the engine loom of a 2wd?
can i fit somewhere the lamba sensor on the engine loom or do I have o search a engine loom of a 4x4 sierra?
sorry about my bad english
cheeRS
Old 24-01-2008, 01:08 PM
rsnissan
rsnissan's Avatar
Yes you can
you need a 4x4 TPS and will need to swap the two outer wires round
you can add the lambda control with the existing loom (run a seperate mini loom from the ECU)
Old 24-01-2008, 02:44 PM
capri280
capri280's Avatar
yes as stated
you can fit an l8 ecu into a 2wd
as stated you need a tff09 sensor to change and swap wires around
i have one fitted to my 2wd installed bt msd and running closed loop
Old 24-01-2008, 02:52 PM
rsnissan
rsnissan's Avatar
the sensor you need is PF09 not ttf09
Old 24-01-2008, 03:07 PM
capri280
capri280's Avatar
sorry i miss typed it
well spotted batman
Old 25-01-2008, 08:21 AM
Yes you can, but if going this expensive way, to get a few more features you may kick yourself that you did not go aftermarket ecu, as it works out cheaper for a LOT more features, some can use any sensor type/rating as well, and are adjustable sensor inputs too, as well as direct coilpack drive Al/LC/TC/ in gear adjustable booste etc, triple map etc etc etc etc.
Old 25-01-2008, 09:47 AM
tommeke
tommeke's Avatar
where can I find this type of sensor?
and how difficuld is it to connect it?
who's the best man to contact? stu @ MSD?
Old 25-01-2008, 02:39 PM
rsnissan
rsnissan's Avatar
second hand of of any 4x4 cosworth (see if a car is being broken in the parts for sale section)
its is very easy,its is just screwed onto the the throttle body and there is a multi plug (the one you have to swap the wires round on)
I'd get one second hand, you can get the lambds sensor itself from stu though
Old 26-01-2008, 09:37 AM
tommeke
tommeke's Avatar
thx for your advice mate
JK12
33
26-04-2021 12:09 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
RSmark84
13-09-2015 01:29 PM
jc1989rs
05-09-2015 08:09 PM
Quick Reply: L8 ecu in 2wd cossie?
