oils pressure
Old 04-01-2008, 04:49 PM
155lee
155lee's Avatar
Default oils pressure
what ideally should my oil pressure gauge read on my 2wd cossie,i have just fitted 1 and it looks really nice but i dont know if i have good pressure or not,which makes it a bit useless!cheers
Old 04-01-2008, 05:40 PM
Jimboxr4x4
Jimboxr4x4's Avatar
Mine idles at about 20 - 25 psi when fully warm with 10w60 castrol but it will depend on the oil you have and also some gauges are more acurate than others. My Tim gauage is shite.
I think the book figure for a new engine is something like 34 psi cold and 24 psi warm or thereabouts. There are threads on here if you do a search.
Old 04-01-2008, 05:49 PM
Jimboxr4x4
Jimboxr4x4's Avatar
Found the thread I posted when I first got my saph. I was using Mobile 1 then:
https://passionford.com/forum/viewto...845&highlight=
Old 04-01-2008, 05:50 PM
155lee
155lee's Avatar
i have the ford racing gauges,i fired it up for around a minute earlier to see if it worked,think it was up around 30+ psi.
Old 04-01-2008, 07:29 PM
Jimboxr4x4
Jimboxr4x4's Avatar
That seems a little low for a cold engine. Mine is usually 40psi + when cold but defends how thick your oil is.
When I had mobile 1 it was about 35 psi as I recall and is around 40+ now on castrol RS.
However, I think its more the throughput of oil that is important, more so than the pressure so i'm sure thats fine anyway.
Old 04-01-2008, 09:00 PM
big mac
big mac's Avatar
I got ford racing on 5-40 valvoline 60 psi cold and 22 after good run
Old 05-01-2008, 12:03 AM
Jimboxr4x4
Jimboxr4x4's Avatar
I would say that is way too thin mate. 10w50 is personally the thinest I would go.
Old 05-01-2008, 07:48 AM
MARCOSWORTH
MARCOSWORTH's Avatar
Mine idles at 60psi cold and 25-30psi hot,driving at 50psi hot with 10w50
Old 05-01-2008, 05:10 PM
NUTTIN RILLA
NUTTIN RILLA's Avatar
Mines is 85psi cold 40psi hot
Old 05-01-2008, 09:34 PM
Cosworth Bassie
Cosworth Bassie's Avatar
Mines is 75 PSI cold at idle. 38 PSI when hot on idle.
Old 07-01-2008, 02:01 PM
Paul_RS
Paul_RS's Avatar
Mines 50psi cold/25psi warm on mobile one 15w50
SMILER258
28-09-2015 09:04 AM
Quick Reply: oils pressure
