MAP Sensor mounting ...
... I thought I'd start a post as I'm looking for these rubber bushes/isolators for the bolts that mount the MAP sensor to the bracket to the inner wing I know my hardware is not stock (they are stainless socket head bolts) ... but everything else in the engine bay is.
I want to replace these bushes if I can get them. Here's a piccy of the best one ...
and the bracket ... (the left hand one)
Upon asking the question in 'parts for sale' it seems that the standard mounting for the MAP sensor is different for a 3 door and a sapphire ... aparrently these bushes are unique to a 3 door as a saph has welded nuts on the bracket.
Is this correct? I thought it was an interesting question as obviously their purpuse is to prevent vibration damage to the MAP sensor.
Moser
Moser
Mine on the saph is like everyone else's with welded nuts on
Your bracket looks like a orignal one by the shape ect so very strange unless someone's cut the nuts off to make it look smother/nicer
Originally Posted by Stu @ M Developments
The bushes were only fitted to very early 3 doors pal.
I still haven't heard from anyone else who has these bushes ... at least I know a little bit more about my car now (in addition to the full folder of receipts )
Mount your sensor direct to the chassis with confidence mate, all will be fine.
Originally Posted by rinus_2005
maybe offtopic, but does the metal ring on the map sensor need to make earth to the chassis?
I ensured this terminal had a good earth (bare metal chassis and ring terminal ) ... but it comes from the harness and then goes to the mounting brackets lower bolt ...
Is this different to?
DixieTheKid
11
06-06-2020 11:20 AM
wheelwizardrefurbs
24-09-2015 08:35 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
