Standard yellow injector
Hello!
Does anybody know the flow rate of standard yellow injector which is in Cosworth 2wd?
Has it any part number?
It is a bosch or weber/marelli item?
Thanks
Thanks
They are BOSCH, if you give me the part number I will look it up for you, have none to hand to look at number, but they are roughly rated as a set to around 270/280 bhp if that is any help.
Okay thank i will try to see the part no,
but i have to know the flow rate in cc/min or lb/hr to VEMS. It is a custom motor management system. The other datas (rise time fall time etc) wil be fine to know.
Thanks
Thanks
Bugger I was thinking after I posted I thought they might be webber!!
They are 2746/02's/F0185.
These are 3.52 GRAMS per SECOND OR 211.2 GRAMS PER MINUTE.
Porsche 944 3.0 ones are 214.3 grams/min but they normally run 3.7 bar.
Other close ones are VOLVO turbo(4), Pontiac Turbo 2.0l turbo.
DixieTheKid
11
06-06-2020 11:20 AM
