stage 3 - what next??
i went out and bought myself a fiesta diesel this weekend so i can keep the cos as more of a weekend toy
this means i no longer need to rely on it, everyday so can start modifying it more, or just making it better.
the current spec is MSD closed loop stage 3, standard T3, greens 3 bar etc
where should i go from here.
should i ditch the air-con and go for a 500 spec cooler?
i dont really know where to go from here regarding the engine?
should i go for a t34, or wait till the T3 goes pop?
recomendations please guys
the gear box is ok, a little noisy
if its breaks i'll replace it, just wondering what my options were regarding the engine
what sort of boost are people running, think the previous owner set mine a little low, as to save the gearbox
whats safe to run on a stage 3 and a 4x4 cooler
T4 and Blacks
Stu MSD ran T34 & blacks and had a good solid 400bhp. He did put a new standard ford box in thou.
If your not using the car all the time now T34 and big cooler and you will be more than happy with Stg3 power
You WILL need a Group A or uprated Headgasket at this point mate!
Cooler and Turbo are the next step but if you suspension and brakes are not up to more power don't even think about it until they are sorted
will prob be dumping the air con soon and maybe going for a t34
cars no longer used everyday, so can get a little more power
as for the head gasket, no worries there
so if i went out and bought a t34, ditched the air con and fitted a 500 cooler (and group a-coil)
would i notice the difference, even running the same boost?
will i have to get a new chip for the t34, or will it be fine on my current msd closed loop set-up
JK12
33
26-04-2021 12:09 PM
Mc5506
05-10-2015 09:57 PM
