MK1 FRS mtx75 speedo drive conversion ?
Is it possible to convert the electronic speedo drive back to the mechanical type ? If so which box/speedo drive do you use ?
Thanks.
Thanks.
There are also something called speedo cable drivers. A box where you feed the electric signal in and it rotates the speedo cable with matching speed. Not very difficult to make one either.
TPM961
15-01-2018 10:50 AM
