Steering wheel Juddering
Old 15-05-2007, 12:27 PM
G1EN
G1EN's Avatar
Default Steering wheel Juddering
What would cause the steering to Judda (and feel like the wheels are about to come flying off) when travelling at any speed ove 50MPH with very slight Left or right movement on the steering wheel.
and i get a very orrible klonking noise on the suspesion on the tinyiest of bumps.
(think i went over an ant the other day and swore the strut was gna shoot straight through the bonnet.)
Im running on KONI's which have only covered 12k miles.
Old 15-05-2007, 12:47 PM
EssexBoyRacer
EssexBoyRacer's Avatar
Punctured tyres
buckled wheel, wheel nuts loose, hub nut loose, knackard steering rack.
Old 15-05-2007, 12:55 PM
G1EN
G1EN's Avatar
Originally Posted by EssexBoyRacer
Punctured tyres
Im feeling ya there
But its definitly not Puntured tyres, Buckled wheel, Loose wheel nuts, no idea on the hub nut (but wouldnt think so), If its the rack then i have a spare Brand New one to replace.
Was just seeing if anyone had exerienced these kind of symptons.
Old 15-05-2007, 01:12 PM
auralisRS
auralisRS's Avatar
It could be a number of things, are all the weights still intact on the wheels from balancing. ?
If they are, jack up the car each front wheel separately and check for play, first holding hands 12 and 6 oclock then 9 and 3. There will be a slight amount of play on the 12-6,thats normal, then do 9-3 this will show any play in the rack or track rods.
Also have you replaced the TCA rubbers on middle and end to Nylon items, worth doing, my Saff suffered badly with this...it cured it.
Having said that, my Esc is wobbling slightly now, as I had a puncture a while ago and it obviously hasn't been balanced well..it was fine before.
Check rack bolts too...mine came loose once.
Old 15-05-2007, 01:33 PM
MarkN
MarkN's Avatar
It could be that the metal mounting cups on the top of the front shocks are breaking up. Escort Cossies are reknowned for this - when I bought mine both were broken very badly and needed to be replaced. When they break the top of the strut can move where it mounts through the suspension turret - the car will wander, shake and crash over bumps in the road. You'll also get a nasty knocking noise when you turn, accellerate or brake.
You can inspect them by taking the top nut off the strut whilist it is still on the car. If you then lift of the top metal cup and look through the hole you'll be able to see if the one underneath is broken. If it has you'll have to take the whole strut off and replace the cup, and you'll need some spring compressors for this.
I've not explained this particularly well but hopefully you'll see what I'm getting at.
Old 15-05-2007, 04:38 PM
TONY F
TONY F's Avatar
had the same thing on mine m8, thought it was wheel balancing but it turned out to be a knackered shocker
Old 16-05-2007, 10:51 AM
G1EN
G1EN's Avatar
Thanks guys.
Shockers are only 2 n half years old. (could they still fuk up in such short time)?
Dont think the TCA's have been changed at all, but when i get my adjustable TCA's ill get some nylon rubbes.
Had new Track Rod end abot 4k miles ago.
Balencing is fine.
Will check the metal mounting cups though.
I have noticed the steering alignment being a bit dodgy even though i keep getting it religned and checked (keep getting told alignment is spot on)
Old 18-05-2007, 10:54 AM
G1EN
G1EN's Avatar
anyone else got any other idea's or wuspect could be the problem, before i put the car in the garage.
Old 18-05-2007, 02:42 PM
cossymad
cossymad's Avatar
Mine broke twice!! now changed for billet items
Old 20-05-2007, 01:37 PM
mxquattro
mxquattro's Avatar
Im fighting this exact problem now with mine. I have changed half shafts, cv joints, center support bearing, front diff, wheel bearings, all new tires.... etc. a whole bunch of things and it has made NO difference. Not even a little bit.
Right now Im suspecting motor mounts though, they are extremely spongy and dry cracked, so I think they are on their way out. In my case the car shakes REALLY bad only when turning left hard. Its perfectly fine turning right, only left. I dont get it. I have had it on the lift countless times checking everything out like tie rods, rack, struts etc. Motor mounts are the only things that look like shit right now, so its my last choice.
ill let you know what I find when I replace them this week.
bob
Old 20-05-2007, 01:38 PM
mxquattro
mxquattro's Avatar
Oh also be sure your axle nuts are tight! +- 238 nm/m
Old 20-05-2007, 01:51 PM
Dave Parker
Dave Parker's Avatar
mine did the same only done 20000 miles
ossie cossie
21-09-2015 05:07 PM
cliffy70
20-09-2015 09:18 PM
dirtysteve
Ford Focus ST
16-09-2015 05:29 AM
Mark RS
Alloy wheels and ICE for sale
10-09-2015 07:27 PM
Adam Graham
06-09-2015 06:04 AM
Quick Reply: Steering wheel Juddering
