No amal valve
Old 21-01-2007, 12:03 PM
Gatecrasher
Not welcome...
Gatecrasher's Avatar
Default No amal valve
Hi
Anyone know why my car haS no amal Valve and the boost/vacum pipes that go to the Turbo and actuator was just hanging there going to nothin at all
my cars had a stage 3 ahmed bajoo / grove conversion would they have took it off?
befor i started taking things off the car was running sweet it was holding boost well, not overboosting ect or running funny at all any ideas?
Old 21-01-2007, 01:32 PM
sailorbob
sailorbob's Avatar
Quite common with conversions, unfortunately a lot of chips do away with the ecu control of boost
Old 21-01-2007, 01:44 PM
Gatecrasher
Not welcome...
ok so i can get my head round that but what about the fact that the boost pipes that was attached to he Turbo and Actuator wasnt connected to anything at the other end?
Whats Controling the Boost presure?
Old 21-01-2007, 02:01 PM
big-dirty-dog
big-dirty-dog's Avatar
my valve is fitted and pluged in but the pipes are blocked off,in place of the amal valve is a manual bleed screw type valve,i have fitted a ggr 2.5 bar chip so ive been told
Old 21-01-2007, 06:28 PM
sailorbob
sailorbob's Avatar
Is the free end plugged?
Old 21-01-2007, 07:17 PM
Dave McB
Dave McB's Avatar
mine dont run an amal valve either.
its there, but not plugged in...
Old 21-01-2007, 08:19 PM
Gatecrasher
Not welcome...
Nope! should it be?
Old 22-01-2007, 08:53 AM
sailorbob
sailorbob's Avatar
I would have thought that it would of been plugged and the boost controlled solely by the actuator (it would have to be an uprated one) or the free end would be partially plugged to vent some pressure like a manual bleed valve. If the pipe was unrestricted then I suspect the car would be overboosting due to too much bleed off (but I could be wrong, maybe the bore isn't big enough or the actuator is wound right down).
Old 23-01-2007, 07:25 PM
phild
phild's Avatar
i have brand new amal valve if u want it
Old 23-01-2007, 07:39 PM
Gatecrasher
Not welcome...
cheers phil will let you know if i need it
im not sure if your right about the actuator being wound right down you know if it was then even if it was overboosting then it would only boost as much as the actator would let it wouldnt it?
think the conversion on my car was done over 7 years ago so it may have been how armed bayjoo and mark grove done things back then? anyone?
Old 24-01-2007, 06:30 PM
foreigneRS
Testing the future
foreigneRS's Avatar
the tee piece has a restriction in it
Old 24-01-2007, 11:50 PM
Gatecrasher
Not welcome...
Sweet for that i will have a blow down it to see if your right
steve.rst
15-03-2016 08:01 AM
01-11-2015 06:53 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
rs_jim
19-09-2015 08:41 PM
Quick Reply: No amal valve
