escort cosworth wheel
Old 13-01-2007, 12:50 PM
RS LOZWORTH
RS LOZWORTH's Avatar
Default escort cosworth wheel
what is the 'J' size of an escort cosworth rim and what is the smallest tyre size it can fit on?
Old 13-01-2007, 02:16 PM
JHS
JHS's Avatar
Escort Cosworth wheel is 8x16" et25. Standard tyre size is 225/45-16. What you can squeeze on is a good question, depends on what youre using them on really... 215/40-16 or 205/45-16 maybe?
Old 14-01-2007, 08:21 AM
Dave Henshall
Dave Henshall's Avatar
i'd ask why would you want to fit a as narrow tyre as possible anyway...?
are your fronts rubbing on your front shockers by any chance....?
if so, you need to mod the spring platform on the shocker, later sets of konis etc alrady have the outer edge of the platform bent up to allow the fitment of bigger wheels without them rubbing...
8J is std which = 225 wide.
i'd go wider to 235 rather than less to 215 or 205, it will look wrong IMO, the rim will be wider than the tyre and be prime candidate for getting kurbed - and look like a replica
Old 14-01-2007, 08:23 AM
Rolls
Rolls's Avatar
Could be for snow tyres I guess?
Old 14-01-2007, 08:24 AM
Dave Henshall
but u'd have to fit 15" rims to fit snow tyres and/or chains unless you wanted to fook your arches up
Old 14-01-2007, 08:26 AM
Rolls
Rolls's Avatar
Hadn't thought of that
Old 14-01-2007, 09:01 AM
RS LOZWORTH
[quote="Dave Henshall"]i'd ask why would you want to fit a as narrow tyre as possible anyway...?
i'd go wider to 235 rather than less to 215 or 205, it will look wrong IMO, the rim will be wider than the tyre and be prime candidate for getting kurbed - and look like a replica [/quote
yer my tyres rub on arches on the fron i had 205's b4 and the wheels i got now have 225 on and it rubs so i was gonna take the 205's of my old wheels......
Old 14-01-2007, 09:33 AM
JHS
JHS's Avatar
I've got 205/50-16 winter tyres on my standard rims, no problem. Will be using 205/55-16 when I get new tyres.
Old 15-01-2007, 07:25 AM
Dave Henshall
what offset are your wheels, the std offset should be no where near rubbing the arches even with 235, nevermind 225, the std offset it ET25 btw.. have you got some ET-10 or similar - ie really wide track..?
post a pic up of the wheels you have on...
Old 15-01-2007, 12:43 PM
RS LOZWORTH
sorry i forgot to say the wheels are on a saff cossie
Old 15-01-2007, 01:15 PM
Dave Henshall
ah yes, the arches on a saph are designed to accomodate ET34 wheels that are only 205 wide, so the escos ones will sit 9mm further out plus an extra 20mm for the tyre, IIRC you cant get away with it without having the arches lips rolled up, or fit the non escos , escos style wheels
Old 15-01-2007, 04:43 PM
RS LOZWORTH
i think if i fit m5 205/45 16 tyres to the rims i may just get away with it thow...
Vincereese
01-06-2023 09:14 AM
Rs_Motion
Escort MK 5 / MK 6
43
27-12-2018 11:49 AM
Vincereese
18-08-2015 03:57 PM
Vincereese
16-08-2015 06:38 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: escort cosworth wheel
