Fitness / Weight Training Discussions Don't drive around with 4 chins! Chat to like minded folk in here and get yourself back to a decent health and fitness level in no time.
carb dependant?
Old 07-03-2006, 08:19 AM
RSPTG
RSPTG's Avatar
Everyone is different at the end of the day and some people get on better on certain micronutrients than others.
I would keep an eye on your portion sizes, you want to get rid of a few extra pounds so it is important to know the amount you are consuming...especially carbs.
If you have worked out your daily calorie requirements for your goal then carbs have there place. Once you have this figure, follow the ratio below and you can keep the carbs in.
Protein 40%-Carbs 40% and Fat 20%.
So you can have the spuds, rice and pasta just in the correct amounts even if you end up weighing it. Then fill your plate with veg or salad to bulk the feed and eat every 3 hours and you should be fine.
Work out your calories and follow the above then you will adjust and reep more results.
Start with your weight in stone x 14 = ? x10=daily calories required to loose. This is a starting figure so see how you go and adjust as needed.
Then split into the 40%-40%-20% as above then into six meals a day and you are ready to shed the pounds.
Hope that helps.
Old 08-03-2006, 08:38 AM
RSPTG
RSPTG's Avatar
Yes Matt.
Start at 1890 per day if you want to shift some weight. This is a starting point for your weight and see how you go.
Protein 40% = 756calories /4 = 189g per day
Carbs 40% = 756calories /4 = 189g per day
Fat 20% = 378calories /9 = 42g per day
You do need to eat 6-7 small meals a day, by doing this you will store less fat and boost your metabolism which in turn will burn calories.
One meal a day will not work.....if you starve yourself or don't feed your body it will actually store fat. This is because the body goes into survival mode as you are depriving it of nutrition, so will store what it can.
Not hard to figure mate...
Breakfast
Snack
Luch
Snack
Dinner
Snack
You will feel better following the above and have more energy, have a look through some of the other post on the foods, this one may help..
https://passionford.com/forum/viewtopic.php?t=152307
If you can't work out the above I suggest you send Paul Eggleton a PM and he will do it for you....will be money well spent if you are serious.
Good luck mate
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
sridgett
01-10-2015 07:30 PM
Orion_Gav
29-09-2015 04:50 PM
sridgett
13
27-09-2015 06:03 PM
Quick Reply: carb dependant?
