PC bods, laptop help!
Ben
Haven't been bothered with it lately as we have a PC now but I could do with getting my laptop back up and running.
Problem being is that the last time I used it, it kept restarting itself after trying to install windows updates. The blue screen that gives you a "Stage x/3 complete", well it gets to stage 3 which is the installing updates part, but never gets past 0%, and after a good 10 minutes it reboots itself and restarts the same process!
Any ideas?
Ben.
Windows Vista by the way.
Any ideas?
Ben.
It's having trouble installing an update, hence you are in a loop. Have you tried booting into safe mode?
Failing that, you have a several other options, another is 'Last known good configuration' this, as the name suggests will boot the system in this state, these are the first two to try.
Martin
Martin
Ben
Martin
Martin
Where do I find "Last known good configuration"?
Thanks.
Stu @ M Developments
41
21-08-2015 06:47 AM
Thrush
25-09-2004 08:25 PM
