Wheels and Tyres Wheels and Tyres for all Ford's
paint help needed please
Old Jan 9, 2011 | 09:35 PM
alexno1dj's Avatar
alexno1dj
Default paint help needed please
hi people,
is it important to put a key onto a topcoat of paint before adding laquer? if so, what would i use? 1200 grit paper or scotchpad?
wouldnt it spoil the paint if i did this?
many thanks, alex
Old Jan 10, 2011 | 12:47 AM
alexno1dj's Avatar
alexno1dj
anyone know about painting wheels? im almost there now, just need the advice on laquer
Old Jan 10, 2011 | 12:51 AM
paddyrs's Avatar
paddyrs
you clean it with pre wipe then put the laquer on
Old Jan 10, 2011 | 06:13 PM
xr_craig's Avatar
xr_craig
I assume you mean basecoat? If so then no don't touch it before lacquer. Any marks will show through and you'll have to start again.
Old Jan 13, 2011 | 10:08 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
If its base a and clear coat then dont touch it. you can flat the base then polish up for a perfect finish. If its solid you using then you van lightly flat inbetween coats if you can be bothered to wait for it to dry first, Or as with base, just half coat then full coat and wait to dry then flat and polish, easy
jessie_rs
11
Jun 3, 2019 04:57 PM
JPA
Nov 8, 2015 12:26 PM
borboyous
Aug 22, 2015 11:17 AM
john_3.0s
Aug 16, 2015 06:40 PM
col93saphcos
Aug 7, 2015 03:21 PM
