need advise (gearbox on s2)
Old Jan 29, 2006 | 03:53 PM
martinmace's Avatar
martinmace
Default need advise (gearbox on s2)
fucking bollox my gearbox is noisy as hell it sounds like its a cv joint gone you know the sound!!!but it is deffo coming from box if i engage the clutch it does not go away only if the car is at a stand still?? could this be bearings diff? or is the box most probabal fucked also i might sound dull as fuck but the box is a rebuilt BC box with an uprated lsd and 1.8 diesel final drive whats the 1.8 diesel final drive all about need some urgent help as i have to change the clutch to but dont know what the fuck to do with the box
Old Jan 29, 2006 | 09:24 PM
martinmace's Avatar
martinmace
Old Jan 29, 2006 | 11:00 PM
NUTS RuS's Avatar
NUTS RuS
You have been told where to get a decent box from quite a few times now
All this cutting corners is getting you nowhere other than wasting money.
Old Jan 30, 2006 | 03:58 PM
dave knight's Avatar
dave knight
can you please tell me where to get a decent box as i have not been told.i
know of all the usuall places cts ,geartorque etc but could do with a
recommendation.cheers
Old Jan 30, 2006 | 05:47 PM
NUTS RuS's Avatar
NUTS RuS
Whats the car / application (road / track / competition etc) and torque power put through it Dave.
But your not far off with CTS
Old Jan 30, 2006 | 05:58 PM
martinmace's Avatar
martinmace
nobody has told me where to get a box from?? i dont want a new box i am still trying to find out what is wrong with the one i got before i decide what to do next so i dont have to spend money unecessarily i have been told where to get a clutch from which is something i did ask for. i have been told it could be the lay shaft bearing if this is the case i can get that done for Ł50 but i am unsure cos as i said it sounds like a fucked cv joint knocking and its also wining.i have replaced the drive shafts today with new ones so it deffo aint cv joints.
Old Jan 30, 2006 | 06:19 PM
dave knight
its a 19 cvh.145 bhp @wheels in a mk 2 xr2(single twin choke carb dmtr).going for bike carbs in summer so add another 25bhp.what dya reckon?torque is 140lb ft at mo
without bike carbs.
Old Jan 30, 2006 | 06:22 PM
NUTS RuS's Avatar
NUTS RuS
Appologies then I was confusing you with someone else.
It could be a bearing, they get worn with age and use, then start to rattle round a little, then wear out the carrier where they sit. This then needs milling out and a bigger bearing putting in if its on the inner case, or parts replacing if its on the shaft.
Only real way to tell is to strip it and have a look around. If the box is off the car how much play is in the shaft ?
Old Jan 30, 2006 | 06:25 PM
NUTS RuS's Avatar
NUTS RuS
Are you struggling with a standard one then ?
CTS are only a phonecall away and all advice from Stuart or Bernie is totally free.
Sounds an interesting motor
Old Jan 30, 2006 | 06:48 PM
dave knight
yeah standard xr box.mainshaft on its way out.will give them a call cheers.
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
A.t.p
Sep 29, 2015 05:04 PM
