problem since fitting rs 500 intercooler
Old Jan 25, 2006 | 05:42 PM
cosbag's Avatar
cosbag
Default problem since fitting rs 500 intercooler
i have recently fitted a rs 500 intercooler to my 2wd cossie , since fitting it i have got a loud chattering noise before the dump valve kicks in i was wondering if anyone has had this problem, it sounds like anti lag but its not that, it is running 19 psi of boost t34 turbo 803 greens 3 bar and 34 actuator i would be grateful for any advice cheers cosbag.
Old Jan 25, 2006 | 05:44 PM
rapidcossie's Avatar
rapidcossie
i had my car checked on the rollers after fitting a 500 cooler.
not sure what your prob is mate but best to get air/fuel ratio checked after fitting cooler??
Old Jan 25, 2006 | 07:21 PM
matcossy's Avatar
matcossy
The noise that you say you are hearing sounds to me like waste gate chatter! hope this helps
Old Jan 25, 2006 | 08:20 PM
cossie604's Avatar
cossie604
how many topics have been posted about the confusion between waste gate chatter and compressor surge now?? lol
It may be just down to the increase in charge air volume mate...but, have you checked that the dump valve aint sticking (in the case of a piston type)...and have you checked your vacuum pipes??
Stu.
Old Jan 28, 2006 | 11:05 AM
rapidcossie
Stu.
is it not the waste gate that chatters??
Old Jan 28, 2006 | 11:36 AM
wimwerf's Avatar
wimwerf
Stu.
no...because it dont existed (spelling)....a wastegate cant chatter...its the compressor wheel which chop the air which is forged back trough te compressor housing..
Old Jan 28, 2006 | 07:41 PM
2wd's Avatar
2wd
Stu.
sorry for asking...but what is compressor surge ???
Old Jan 29, 2006 | 08:01 AM
cossie604's Avatar
cossie604
As wimwerf said, compressor surge is the sound of the compressor wheel chopping up the charge air thats being forced back though it the wrong way when the throttle is shut mid boost
Old Jan 29, 2006 | 08:38 AM
2wd's Avatar
2wd
Hmmm...ok...I might be asking stupid again ...but how can I tell the difference between surge and chatter... ??
Old Jan 29, 2006 | 09:12 AM
cossie604's Avatar
cossie604
lol have you got an external waste gate fitted?? If not, then your hearing surge....a noise that many people confuse with waste gate chatter...something that you dont get with a normal integral waste gate.
Now awaits many conflicting replies from othe rPassionford memebers lol
Stu
Old Jan 29, 2006 | 11:36 AM
2wd's Avatar
2wd
Stu
ok... I have not a external waste gate, so it must be surge.....so is surge bad or ....
Old Jan 29, 2006 | 02:36 PM
cossie604's Avatar
cossie604
Now your trying to re-open a HUGE debate on 'is surge bad or not'.....in theory its a very bad thing, it puts huge loads on your turbo when running high boost...but alot of tuners do run cars like that with out any short term problems evident. Personaly, I consider it a bad thing, I have a dump valve fitted but with a very heavy spring on it...it releases a little just to take some of the shock out but I still have the demented pigeon stuck under my bonnet sound as well
Stu.
Old Jan 29, 2006 | 04:19 PM
2wd's Avatar
2wd
Stu.
ok..I have a D-valve to...but also the pigeon...
manuel boeckx
13
Oct 3, 2015 02:29 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
RsS2daz
Aug 14, 2015 05:26 AM
