Yet more problems with the rst
Old Jan 24, 2006 | 06:49 PM
fiestar5t's Avatar
fiestar5t
Default Yet more problems with the rst
just took my fiesta rst out for a drive and as i was going down the road my heaters cut out and my fan was not working, also the front fogs would not come on, got her home to check all the fuses but they were fine, its my first rst and ive had nothin but probs with it but there has been nothin major so far,, can anybody help as its spending more time in the garage than on the road cheers
Old Jan 24, 2006 | 07:46 PM
GAZ666's Avatar
GAZ666
i read somewhere that theres a green relay not fuse that controls the rad fan AND the heaters inside, so have you checked that.?
not sure about the fogs...wiring maybe...??
Old Jan 25, 2006 | 11:04 AM
fiestar5t's Avatar
fiestar5t
superb thanx for that mate ill have a look after work ,someone else said the same as you so ill give it a go, ill let you know wot the out come is,,
Old Jan 25, 2006 | 03:24 PM
fiestar5t's Avatar
fiestar5t
Thanx for that mate,i have changed the relay and its working fine now, the front fogs run off the same relay thats why they cut out too!!! i owe you a beer !!!
Old Jan 25, 2006 | 04:35 PM
fiestasimon's Avatar
fiestasimon
where is this relay?
Old Jan 25, 2006 | 05:51 PM
MikeyXR2i's Avatar
MikeyXR2i
In the fuse box, u need to unscrew and drop the fusebox down, there normally all melted and stuck in.
Old Jan 25, 2006 | 06:10 PM
fiestar5t's Avatar
fiestar5t
Simple job mate they are behind the fuse box (as above) unscrew the two screws and the fuse box will be loose pull it down and you cant miss them,took me 10mins to do.. u got problems with yours too mate??
Old Jan 25, 2006 | 07:03 PM
fiestasimon
duno maybe,
my heated rear screen dont work for some reason, plus my fan didnt work.
just want to check em out, c if they are ok,
how can you tell if they are bolloxd.
Old Jan 26, 2006 | 11:21 AM
fiestar5t's Avatar
fiestar5t
i noticed mine by just taking it out you can see on the plastic where it had burnt out,, just pull it out turn it upside down and have a look by the pins for any signs of melting or burning?? hope this helps
Old Jan 27, 2006 | 07:20 AM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
Default Re: Yet more problems with the rst
Have you sorted the green relay?????/ if not i have a few
Matt
Old Jan 27, 2006 | 08:28 PM
fiestar5t's Avatar
fiestar5t
thanx matt, have i thanx, i took one off my dads escort thats been on the drive for a whilst hehehehe its working like new now, thanx for the offer though it is apreciated..
A.t.p
Oct 23, 2015 07:54 PM
DAZZER
Sep 30, 2015 08:43 PM
A.t.p
Sep 29, 2015 05:04 PM
