Intermitent wheel wobble
Old Jan 23, 2006 | 09:30 AM
Mich's Avatar
Mich
Default Intermitent wheel wobble
Over the last couple of weeks going around left hand corners I have been getting really bad wheel wobble and shaking from the front end of the car.
Had the wheels rebalanced and checked all of the wheel nuts, and the top of the front struts, they are all fine, the front struts are only about a year old so hopefully it shouldn't be those.
This doesn't do it all the time though, it has only done this once the past week.
Any ideas as I haven't a clue
CheeRS
Mich
Old Jan 23, 2006 | 09:51 AM
EssexBoyRacer's Avatar
EssexBoyRacer
Could it be when your braking?
Warped discs will cause wheel wobble.
Old Jan 23, 2006 | 10:11 AM
Mich's Avatar
Mich
If it was a warped disc wouldn't it do that all the time ??? which it doesn't
But when it does do it that is what it feels like, I get like a rattling from the front as though something is loose, if that makes sense.
CheeRS
Mich
Old Jan 23, 2006 | 07:43 PM
cocaina_xr2i's Avatar
cocaina_xr2i
wrench it all
check the wheel bearings and bushes m8 if they are just starting to go that's the feeling something to be loose dont think so cos it would doit even when passing a speed bump
Old Jan 26, 2006 | 08:16 PM
sexr3i's Avatar
sexr3i
isn't it
could be a ball joint? other than that I'd say bearing, jack the car up and check the wheel for side to side and up and down motion. replace whatever seems to be giving way.
Old Jan 27, 2006 | 06:21 PM
Philly_F's Avatar
Philly_F
ball joint, bearing. one or the other
just see about getting the whole wishbone replaced
jack the ar up an see if you can wobble the wheel to find any type of movement.
Old Jan 27, 2006 | 11:26 PM
CHRIS82's Avatar
CHRIS82
hiya mate is it a 4x4, if your bushes and bearings are ok it could be that 1 of your driveshafts is worn to check it get hold of the driveshaftshaft and try to move it up down if you get alot of up and down movement then it's knackered i had the problem on an escort and it turned out to be this.
Fiddy
21
Sep 29, 2015 06:10 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Karl @ FPT
Sep 21, 2015 11:17 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
