throttle bodies
hey im wondering if 2.0 L zetec throttle bodies would fit on a 1.6 or 1.8 zetec? just me and me mate are wondering if it will work and what benefits it will have i.e. +bhp and how much gain
cheers
cheers
will fit but will need further changes to optimise. I was gona fit a 54mm TB on my 1.8 but thought not until I get it mappable cos just letting loads of air in won't be ideal TBH as you'll need fuelling raised and ignition curve altered. might not like idle either cos of the low air speed involved.
if you have a 1.8 105 then fitting 130 throttle body, cams and ecu will get you up to the 130spec figures. but just fitting the throttle body will be like fitting a K&N on a carb and not getting it re-jetted.
it does fit, and yes you will gain!
but find yourself a doner Mondeo 2.0 Zetech, get the TB, and the MAF, and if you want some more, get the cams as well.. this will take you to about 125 bhp (with the cams) and to get it at 130 and with a better curve, get it runin with a new chip. Everybody is doing it here en Denmark, and is getting great power gaines for small figures ($$)
mk3ste
Oct 17, 2021 10:09 AM
