Sapph 4x4 Misfire...Any Suggestions???
#44
Can you please confirm for me the following...
If you put the Crank at TDC on No.1 cylinder, look at the phase sensor, where should the 2 lobes be in relation to the phase sensor lobe?
#49
well if the fuel side of it all checks out ok , ..............does this problem happen from cold, and does it start ok from cold,in your opinion is it rich when cold or weak mixture[does it sound like you left the choke on too long or is it a bit fluffy]
#50
the water temp sensor for the ecu have you checked the ohms reading when cold and when hot[these if knackered play havoc with injector pulse widths they can give the same symtoms as low fuel pressure ].......i aint got any more ideas but oh yeh ,on the coil it has push on connectors does it have a little black noise suppressor that links the coil live to the coil wire ,i have known these to break down an cause a weak signal to the coil if it does have one try bypassing it ........thats it im out of ideas let me know if you cure it
#51
oh and as for adjusting fuel pressure regs i have done this loads of times on loads of cars including several cossies the only way to puncture it is to screw it right down and then some!!!!!..... weber supply these for all different types of cars same thing no bung , otherwise why have an adjuster at all why not a plain pressure reg?
#52
Originally Posted by CosRush
Could the ECU be at fault? Just wondered as ive not checked this.
/Thomas Krath
#54
m8 i had that problem and its the injectors i no ther greens but they can still fuck up try changeing injectors with anothers set.oh and if that dont work it the ecu but thats what it is {sorted}
#59
it could depending on how its been removed - what boost are you running - have you had a gauge on it?
did you say it was a red top one, ie, no lambda probe in to top of the turbo?
07-10-2015 01:56 PM
DavidK
27-09-2015 03:55 PM
