kangarooing rs turbo
Old Jul 19, 2004 | 09:41 AM
philrsturbo's Avatar
philrsturbo
Default kangarooing rs turbo
please can any one help me,sat night car started ,missing amnd kangarooing,engine will not pick up,and it is kicking out black smoke,also,every now and then it will pick up and go allright,then die its also ,pressurerising the cooling system rather quickly,
but not over heating ,i dont think i have a melt down prob as it picks up ok
it seem s like fuel starvation,i have fitted a new fuel pump as i thought this was the problem,its the same,any ideas as i am thinking along the lines of burning it out any help would be appreciated,as i am sick of biking to work
Old Jul 19, 2004 | 10:16 AM
philrsturbo
to the above problem i have been told it could be a coolant temp sensor,for the ecu and the car is over fueling ,and flooding the engine does this sound right to any one
cheers phil
Old Jul 27, 2004 | 08:18 PM
jonny664's Avatar
jonny664
if it is a escort rs turbo might be the metering head
Old Jul 27, 2004 | 10:24 PM
goldS2's Avatar
goldS2
def sounds like overfuelling to me try unplugging the electrical connection of the cold start injector on back of inlet manifold if this helps it's prob the temp sensor for the fuel computer. if your car acts ok when cold but worse when warm then this is likely to be the problem.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
