acttuator
Old Jan 13, 2006 | 11:57 AM
rsboy82's Avatar
rsboy82
Default acttuator
hi im just in the middle of fitting my new acctuator
bascially ive gone from a t2 to a t3 with -31 actuator all i need to know is when screwing the bit that fits on the rod and goes to the nipple of the exhaust housing does it matter how far its screwed on?
also does the exhaust flange bit that connects to the actuator does this have to be open or closed as in to the left or right ill get some pics sorted for tommorow cheers
Old Jan 13, 2006 | 02:04 PM
Stu @ M Developments's Avatar
PassionFords Creator
gate goes nearest actuator.
shorten rod so its 3mm too short to hook over, and then stretch teh arm over. This is now your MINIMUM boost setting on that actuator.
Old Jan 13, 2006 | 02:18 PM
rsboy82's Avatar
rsboy82
cheers Stu that helped me out loads that makes more sense now i can carry on with the build now
also how do u measure the boost to the amount of turns
is it something like one full turn relates to 1 psi
cheers
Old Jan 13, 2006 | 04:16 PM
cheers
There is no 100% relation due to teh boost control solenoids action (amal valve) but figure on 1 turn =1.5psi normally.
Old Jan 13, 2006 | 10:35 PM
no grip's Avatar
no grip
oh!
I've just turned my RST'd XR2 up by 5 turns which is +7.5psi = 20psi then.
Ah well lets destroy another CVH lump then
Old Jan 14, 2006 | 11:59 AM
JamesA_RST's Avatar
JamesA_RST
id turned mine up about 8 turns and it was running 23psi!! turned it down now before she gives up! now the actuator is shaged and it holds back at higher boost sometimes!
Old Jan 16, 2006 | 08:58 AM
rsboy82's Avatar
rsboy82
cheers stu for the advice
Old Jan 16, 2006 | 02:36 PM
HORNETS7's Avatar
HORNETS7
and i thought 1 turn was 3 psi or there abouts be carefull do it in stage s not 5 truns first i'd do 3 then 4 .... etc.....
Old Jan 16, 2006 | 02:51 PM
fiestasimon's Avatar
fiestasimon
how can you tell what actuator is on the turbo, ive got a t3 on my frst,
also whats the equiv of 1.4bar, my boost gauge shows that when flooring it.
Old Jan 16, 2006 | 04:23 PM
fiestasimon
anyone?
Old Jan 16, 2006 | 09:38 PM
20ish.
