ECU P8 insted of L8
Old 11-01-2006 | 07:30 AM
bige's Avatar
bige
Default ECU P8 insted of L8
Hi
Is it easy ( just the ECU) too put an P8 in sted of L8 cat on an 92- 4x4 ?
Old 12-01-2006 | 10:01 PM
Stu @ M Developments's Avatar
PassionFords Creator
As long as the car has a working lambda sensor installed, yes.
Old 13-01-2006 | 11:12 AM
sygjim's Avatar
sygjim
you need no other mods ????
Old 13-01-2006 | 11:14 AM
None.
Obviously the software you put into teh ecu has to be suitable for your engine and mods.
Old 13-01-2006 | 12:25 PM
bige's Avatar
bige
no 2,5 bar map ? standar ECU
Old 13-01-2006 | 12:41 PM
No then, as the Escort Cosworth has a larger turbo, possibly a chargecooler if an early model and obviously the wrong map sensor too. I naturaly assumed you would know the software needs to be changed as the 2 engines are different as std.
Old 13-01-2006 | 01:27 PM
bige's Avatar
bige
e-mail sent
Old 13-01-2006 | 08:44 PM
sygjim's Avatar
sygjim
so, it's not a good idea to use the p8 instead of the l8, to have a closed loop?
Old 13-01-2006 | 08:52 PM
P8 can do closed loop fine, but ANY ecu needs to have the correct chip to run the engine. Its not teh P8s fault that as standard it runs a different engine.
Plus, P8 is far more expensive, it would be cheaper to use your L8 IMO.
Old 14-01-2006 | 05:34 AM
bige's Avatar
bige
as for my self i was thinking L1 schanged too L8 is better on my 86 . later teknologi . Then P8 is newer than L8 . Thinking P8 has an overboost ? and not puting the HP up , just a litle bit more som sec ?
closed loop - pleas explain , not familiar ........
Old 14-01-2006 | 07:04 PM
sygjim's Avatar
sygjim
for the closed loop, you can search "closed loop" on the website, you will understand what it is
Old 15-01-2006 | 08:59 PM
foreigneRS's Avatar
foreigneRS
Testing the future
bige 'closed loop' is short for closed loop fuelling.
in simple terms, it mean that the amount of fuel that is injected into the engine is checked by the lambda sensor. if it is too much, less is injected next time and then it is checked again.
i.e.
inject <-
___v___^
check ->
Old 22-03-2006 | 06:32 AM
sygjim's Avatar
sygjim
if you fit a pectel board on a p8, you need the lambda ?
somebody told me that it's not necssary
Old 22-03-2006 | 07:10 PM
sygjim's Avatar
sygjim
up
Old 22-03-2006 | 09:09 PM
Dave Henshall's Avatar
Dave Henshall
the pectel software on p8 doesnt use the lambda probe, no
yes, the p8 can copntrol overboost aswell, but it needs a 2port valve, like the one fitted to the esocs, the std sierra amal valve wont work. it will click and operate , but it wont work as a boost control device.
Old 23-03-2006 | 07:05 AM
sygjim's Avatar
sygjim
thanks
so to resume, with my pectel board on a p8, i won't fit a lambda on my sierra, and i need to desactivate the amal valve?
what the t35 escort use to control boost instead of amal valve?
Old 23-03-2006 | 07:15 AM
sygjim's Avatar
sygjim
thanks
Old 23-03-2006 | 08:30 AM
foreigneRS's Avatar
foreigneRS
Testing the future
that's a bit shit that the pectel board doesn't do closed loop. why use a pectel board then? why not go back to a std one, so that you have closed loop?
the escort uses what's called a 'Lektron valve' in conjunction with a calibrated bleed t-piece. IIRC it works in a similar way to the air injectors, which is opposite to the sierra amal valve.
do a search for it, there was a topic a while back about it (maybe before the crash?)
Old 23-03-2006 | 08:34 AM
Dave Henshall
this is the big question, and the answer usually comes out as because i want to either be able to map it myslef using the pectel software, or a want to run coilpacks, WI, ALS etc without the need for any more hardware as the pectel software supports all this whereas the std software doesnt
Old 23-03-2006 | 11:44 AM
foreigneRS's Avatar
foreigneRS
Testing the future
so what you want is a software solution for P8 that can do all of those things including closed loop fuelling?
Old 23-03-2006 | 11:55 AM
Dave Henshall
yep, stu's software can map the fuel, boost etc, but hasn't been writted to enable the other things, it probably can be done by just chaingin a 0 to a 1 or a 00 to FF or similar, its just know which one in the HUGE list of them in teh ecu's memory
Old 23-03-2006 | 01:19 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i'm sure that it can all be done
Old 23-03-2006 | 01:37 PM
Dave Henshall
with enough time by trial and error , yes
Old 23-03-2006 | 01:38 PM
_DAN_'s Avatar
_DAN_
Yoon
Interesting reading
Old 23-03-2006 | 01:51 PM
foreigneRS's Avatar
foreigneRS
Testing the future
or by reverse engineering the original software like pectel did
Old 23-03-2006 | 02:39 PM
Dave Henshall
yep, but who could do such a thing now - a lot of time money and effort went into it, and then if u did it again, you would want that investment protecting, roll on an encryption board....
Old 23-03-2006 | 02:52 PM
sygjim's Avatar
sygjim
thanks
another question, where find the pectel software ???
It's a free one ?
Old 23-03-2006 | 03:22 PM
Dave Henshall
there are a few copies knocking about, (think you need a dongle for it to work, not 100% sure though) and then when u've done the mapping through an emulator, you still need a pectel board for it to work when burnt to a chip.
i'd just get it mapped by stu or similar, someone who knows what they are doing, you don't want to practice on your own engine... well i dont anyway
Old 23-03-2006 | 03:35 PM
sygjim's Avatar
sygjim
thanks, it was just for looking and try to understand how it's work
i have a pectel p8 board, i will fit it on my cossie in few days
Another question, i suppose that i need more looms to have for example the air to air boost controleror or als ????
Old 23-03-2006 | 03:41 PM
Dave Henshall
you need a small sub loom for the air to air , and the als it just a pin on the ecu which through a switch to activate goes to ground on the bodyshell. most of the pectel developed stuff like that has pectel sub looms already available IIRC
Old 23-03-2006 | 03:47 PM
sygjim's Avatar
sygjim
thanks
but the chips had already the programfor that ?
Old 23-03-2006 | 04:44 PM
Dave Henshall
cool
Old 23-03-2006 | 05:13 PM
sygjim's Avatar
sygjim
could you tell me if i need to replace the amal valve by the lektron (and the loom) ???
Old 20-06-2006 | 10:08 PM
the original's Avatar
the original
bttt for an answer to sygjim about the 'lektron'
Old 21-06-2006 | 12:32 PM
Dave Henshall
yep, as the 2 walves and the pipework connect to them and the actuator are completely differenrt,
the lectron valve control the amount of boost, whereas the amal valve just stops boost increasing at a pre detirmined level - - in an oversimplified view...
mark94
Ford Mondeo Including ST
10-10-2023 07:52 PM
griffo69
04-10-2015 12:58 PM
R4N SS
Ford XR Parts For Sale
15-09-2015 04:38 PM
DixieTheKid
14-09-2015 10:04 PM
Tank Mike
14-09-2015 04:56 PM
Quick Reply: ECU P8 insted of L8
