battry light
Old Jan 10, 2006 | 05:39 AM
smitsturbo's Avatar
smitsturbo
Default battry light
ive just finished my project fiesta its a 2.0l zvh with turbo g/box & twin dcoes but it starts no bother with a jump but the battrey lights on ive changed the alternator, checked the fuses & earths & the battrey itself but it just keaps cumming back on & cutting out the car any help my fellow fordy folk chears in advance
Old Jan 10, 2006 | 03:16 PM
Phil DJ's Avatar
Phil DJ
Is the alternator powerful enough?
Right output, etc. etc.
Old Jan 10, 2006 | 03:23 PM
SafeChav's Avatar
SafeChav
Hello mate
thats a wierd one, if the battery light stays on there must be a wiring fault then, the battery light has a switched ignition supply, and then is connected to the alternator, which when NOT charging is earthed (negative), but once it starts charging it changes to positive (and as you know the bulb wont light if both sides are connected to positive). Also the alternator cannot commence charging without the battery light, at a guess i would say you have connected the thin blue wrie to the wrong point on the alternator, it sounds like its connected to something that is part of the alternators body.
Let me know how u get on
Old Jan 10, 2006 | 10:31 PM
smitsturbo's Avatar
smitsturbo
theres three wire's going to the alternator 1 thin green & yellow 1 & 2 red 1,s ive swapped the red 1,s about to see if theres a change but no go its going to a tuners to get set up soon but i,ll ask if he can sort that out too but was a bit worried incase he charges me for things ive already checked
Old Jan 10, 2006 | 10:58 PM
SafeChav's Avatar
SafeChav
ah right, sorry the blue wire i refered to is the thin green/yellow on yours then, BE VERY CAREFUL where you put those red wires they connect to an unfused supply from the battery (very dangerous if you connect it wrong).
The red ones should be joined together in the same connector (unless theyve been replaced) and should both run to the starter motor, on the same connector as the main battery lead, the green/yellow is the wire you need to be looking at, can you get me a picture of it from above/underneath, i can more than likely help you then
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
