dump valve question
Old Jan 10, 2006 | 12:00 AM
Dub-Se7en's Avatar
Dub-Se7en
Default dump valve question
hi all,
i am building a zetec turbo using mostly sierra cosworth parts including the management, turbo and throttle.
should i be using a dump valve? if so, what type would you reccommend? (i want one that sounds good too!)
Cheers peeps
Ian
Old Jan 10, 2006 | 09:39 PM
D0N7_5H007's Avatar
D0N7_5H007
you dont have to, if you are using an old floating point bearing turbo it may extend its life but if you are going for a newer ball bearing turbo it doesn't make much difference.
Old Jan 14, 2006 | 08:37 PM
HORNETS7's Avatar
HORNETS7
ah well if u want a dump valve i recommend a forge motorsport one !!!!
Old Jan 16, 2006 | 04:56 PM
mach's Avatar
mach
I'm with Hornet on that one... I have a Forge Dump valve on my RST S2 and it sounds GREAT.. you gotta love that sound
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
richierich1986
Sep 18, 2015 03:29 PM
