gear box oil
Old Jul 17, 2004 | 02:56 PM
ian rst's Avatar
ian rst
Default gear box oil
Ok just bought some gear box oil for my esc cos but how do you put it in there? Do i need an adaptor for it to put on the end of the bottle?
Old Jul 17, 2004 | 03:28 PM
Dave Henshall's Avatar
Dave Henshall
in the gearbox, 1.3 litres.
in the transfer box, half a litre.
Old Jul 17, 2004 | 04:55 PM
ian rst's Avatar
ian rst
Thanks for that but how do i get it in there?
Old Jul 18, 2004 | 08:55 AM
JohnP001's Avatar
JohnP001
It’s quite tricky, as the filler plug is on the side, and you cannot lift the bottle high enough for a gravity feed. I used my brake bleed kit. I filled the bottle with the gearbox fluid, then pressurised the bottle with my compressor (approximately 10 psi) which forced the oil up out of the bottle, and into the gearbox. Worked like a treat. Did the same for the transfer case.
Old Jul 18, 2004 | 09:06 PM
dave cos4x4's Avatar
dave cos4x4
i bought the stuff in a bottle with a long tube as a neck and squeeze it like fook to force it in.
Keep the bottle in the garage for next time.
Dave.
Old Jul 19, 2004 | 10:37 AM
ian rst's Avatar
ian rst
I got mine from Ford so no long neck
Rizlablue
Sep 6, 2015 09:58 AM
Adam Graham
Sep 6, 2015 06:04 AM
oilman
Trader Parts for Sale.
Sep 4, 2015 09:34 AM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
