Cosworth Wiring Problem
Old Jan 7, 2006 | 09:36 AM
scottiemous's Avatar
scottiemous
Default Cosworth Wiring Problem
I've found out what pin positons are on the TPS (thanks CosRush), but can anyone tell me
which colours go to which pin position on it.
It's a 2wd one.
Thanks...
Old Jan 8, 2006 | 04:31 AM
BMEP's Avatar
BMEP
Hi mate,
If im not mistaken....
Pin 17 is Black with a Red trace (TPS signal into ECU)
Pin 30 is Red (5 Volt feed into TPS from ECU)
Pin 11 is Brown with Green trace (Earth/Negative feed to TPS from ECU)
Note; Pin 11 also feeds the Air and Coolant temp sensors with an ECU earth supply as well as the TPS.
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 14, 2015 07:29 AM
muffster
Aug 11, 2015 05:39 PM
jdsjojo
Aug 1, 2015 08:50 PM
