ERST.. will not start.
Old Jul 16, 2004 | 08:14 PM
wayniac's Avatar
wayniac
Default ERST.. will not start.
fooker !
turns over ok... no prime 'buzz' from fuel pump... maybe fooked relay ? bridged wire from battery to pump... pumps ok then....
does the relay switch anything else that could cause a none starting effect ?
plugs are firing ok.
I can smell fuel around the metering head, but the guy seems to think no fuel is passing and getting to the injectors.
any quick ideas on what to try and what to check / look for etc etc
cheers
Wayne
Old Jul 19, 2004 | 04:41 PM
wayniac's Avatar
wayniac
up
Old Jul 20, 2004 | 09:51 AM
davidnormanuk's Avatar
davidnormanuk
The cheating way to get your car started is to get a small amount of petrol and put it onto your filter so when your turn the car over it will draw in the fumes and fire up. Just be ready to turn the engine off if the revs go sky high.
Dave
Old Jul 21, 2004 | 12:32 PM
flyer1's Avatar
flyer1
give the top of the metering head a sharp thump with a hammer if it is stuck this may release it if it starts u ll now its the the meterin unit to check the relay just take the pink 1 from under the drivers foot well and bridge the to wires across the pump should run constant
Old Aug 13, 2004 | 06:27 AM
RAPID FORD's Avatar
RAPID FORD
JUST AN IDEAR CHECK THE INJECTOR FUSE, BECAUSE I HAD A SIMULAR PROB WITH MY S2.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Mile30
69
May 13, 2017 08:44 PM
A.t.p
Oct 23, 2015 07:54 PM
CossieRich
30
Sep 8, 2015 10:08 PM
fuzzy
Sep 4, 2015 10:11 PM
