Focus Speedo
Old Jan 5, 2006 | 11:58 AM
keithh's Avatar
keithh
Default Focus Speedo
I've noticed that when driving my 1999 Focus Zetec the speedo needle will suddenly drop back to the off position for a few seconds before working again.
It hasn't happened that often, only a few times in the last 8 months or so.
Any ideas what could be causing this?
Cheers,
Keith
Old Jan 5, 2006 | 07:34 PM
filthyrichie's Avatar
filthyrichie
was a recall on vss they renewed the design as they were giving this problem... try self testing cluster hold trip then switch ign on and keep trip pressed all guages ect will have a fit .. if u then let go of trip button u can scroll thru cluster test by pressing trip one push at a time this brings up charge rate ect and also digital speedo .. try roadtesting then and see if guage and digital speed drops if so then replaces vss
ps they are a shi.t to get out as roll pin get stuck in transaxle housing
good luck
Old Jan 14, 2006 | 09:02 AM
keithh's Avatar
keithh
Cheers for the advise filthyrichie, i'll keep an eye on the digi speedo from now on.
cossie brad
Sep 29, 2015 02:38 PM
Sp3no
Sep 27, 2015 07:23 PM
IainRS1700T
Sep 25, 2015 06:44 AM
sto6enc
Ford Mondeo Including ST
Sep 21, 2015 11:31 AM
Bransby
Sep 14, 2015 08:54 PM
