Power Steering Pump pressure
Old Jan 4, 2006 | 10:39 PM
Default Power Steering Pump pressure
Looking to change to Electric PS Pump anyone done this or know the pressure of the Cossie rack. The Astra/Saxo pump looks OK again anyone tried this, dont want to try if its a no-go
Old Jan 4, 2006 | 11:08 PM
Seen it done on calibras, similar size car and rack etc, so shouldnt be a problem
Old Jan 5, 2006 | 12:41 AM
jon@work's Avatar
jon@work
I believe Brom's using an electric pump with his standard rack...
Old Jan 5, 2006 | 08:28 AM
ian sibbert's Avatar
ian sibbert
Rod,
Normal pressure for the cossie pump is approx 60 - 75 bar.....the motorsport versions increase to 90 bar....
Never had the need to do the conversion on a cos....the cos rack suffers at low speed on tight chicanes etc...we have on the past drilled out the standard rack galleries to increase flow....combined with a 90 bar pump this works ok...
I'd say it'd depend on what you were trying to acheive...weight saving?...increase in power?...IMO i'd stick an easy feel rack and a 90 bar pump on....
Regards
Ian
Old Jan 5, 2006 | 11:35 AM
Originally Posted by sibster
Rod,
Regards
Ian
Need to get rid of standard pump to solve a prob. At High revs (8k+) mainly when on Nitrous it sheds its belt. Have had new pump/ belt & lazer aligned but still does it. Not a prob on the road with 7.7K limit. Just looking at all solutions, have found others that have had similar probs.
Rod
Old Jan 5, 2006 | 12:14 PM
ian sibbert
Correct alignment and a poly vee belt i would have thought would be ok...but dont operate at the same extremes you guys do....I know Pete Doughty ran a saxo pump with no probs on his silver Esc WRC to do the active centre diff and power steering.....he may be worth a call....we run the two stage MPC pump with a poly vee belt arrangement....we aint revving as high as you but ive never seen the YB shed a PS belt on a rally engine.....
HTH
Ian
Old Jan 5, 2006 | 12:46 PM
hI
Intrested in a contact number for Pete Doughty & details on Poly vee belt.
Cheers & Thanks Rod
Old Jan 5, 2006 | 02:12 PM
ian sibbert
DPE Doughty Precision Engineering Notts Tel 0115 967 4256 that's the only number I have ATM...I had Pete's mobile somewhere but its been a couple of years since I spoke to him....if I find it i'll pm you...
Poly vee's were used on the later esc cos...
Some pics (apologises for the quality)
HTH
Ian
Old Jan 5, 2006 | 07:20 PM
markk's Avatar
markk
rod you have pm
JK12
33
Apr 26, 2021 12:09 PM
jonfoc
16
Sep 11, 2018 05:35 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
