lsd gearbox trouble
Old Jan 3, 2006 | 10:36 PM
grease monkey's Avatar
grease monkey
Default lsd gearbox trouble
hi guys
im wondering if anyone has any expierience with escort rst lsd differential ive recently bought 2 escort gearboxes and they do have lsd i stripped one box down and removed the diff as im goin to fit it to my fiesta rst gearbox.
there is play in the diff. if you stick your fingers into the diff unit you can move the internals up and down slighty this is the same on both diffs. im wondering if this normal and will it be ok when the drive shafts go in ?
on visual inspection diff looks in good nic and the internals of thegearbox looked reasonably good too no sign of smashed or anything .
i didnt buy the gearboxes for much so it doesnt bother whether the diff is good or not but i would hate go to all the effort of putting it into the fiesta and find its all been a waste.
any info would be greatly appreciated
Old Jan 4, 2006 | 05:10 PM
rsturbowhite's Avatar
rsturbowhite
hope this help yea iv just picked up an old load off spare parts form gearbox builder . in side is one off the lsd witch he said was in good order .iv just put me finger in the drive shaft holes and there is also play
Old Jan 4, 2006 | 05:33 PM
SafeChav's Avatar
SafeChav
I believe the play in the diff is because the differential is viscous coupled, sounds normal
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
Iain Mac
Sep 30, 2015 09:39 PM
A.t.p
Sep 29, 2015 05:04 PM
