lacks power whilest hot, Help.
hi guys,
can anyone help, iv,e got the ecsort gti. it used idle at 3000 revs so i had it in at a garage, they changed the air flow metor with no joy, when i got home i pulled all the electical plus apart and cleaned them up also i disconnected the battary to reset the ECU. it seemed to do the trick.
now yes now you think youve done it but another pops up. when the car is worm whilest accelarating theres no power. its a bone shaker. unless you put the pedle to the floor, then it put you back in ya seat. had it down at ford they had it for 7 hours. they changed the spark plugs and a broken wire on the coil. they said it,s done so i paid up, nothing had changed it still dose what it did before, got it back in at ford in the new year. but will they fix it?.
thanks
HAPPY NEW YEAR
TO ALL
thanks
HAPPY NEW YEAR
TO ALL
Main dealers arent always the best, thats about all i can chip in on this dont know a lot about these. If i were you i would make sure this re-visit to Ford is free seeing as they took your money and told you it was fixed when it clearly isnt, thats just not on! You think they would raod test it before giving it back
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
