head gasket question
Old Jul 15, 2004 | 07:00 PM
Eagle's Avatar
Eagle
Super Moderator
Default head gasket question
ok ... got to take me head off soon ... got a grp a jobbie to go on .... any secrets in how to fit it???? and its a cossie 4x4 on a h plate
cheers
Old Jul 16, 2004 | 12:11 AM
NotNormal's Avatar
NotNormal
Secret's ehh , try putting the gasket between the head and the block
This usually helps
Old Jul 16, 2004 | 03:28 PM
Eagle's Avatar
Eagle
Super Moderator
erm .. no shit sherlock
Old Jul 17, 2004 | 12:37 PM
Dave Henshall's Avatar
Dave Henshall
cut the heads off a couple of the old head bolts and cut a slot in the end so you can screw/unscrew them with a screw driver - use these to locate the head when refitting it - easy service tool.
Old Jul 17, 2004 | 06:30 PM
Eagle's Avatar
Eagle
Super Moderator
cool tip mate
so do you have to get the head skimmed???
Old Jul 19, 2004 | 09:02 AM
Dave Henshall
u dont have to unless it needs it. is it pitted or scorred or warped then yes.
Old Jul 19, 2004 | 09:56 PM
Eagle's Avatar
Eagle
Super Moderator
ahh ok then .. well wont know till i get the thing off then
cheers
Old Sep 12, 2004 | 09:47 PM
blaazer2's Avatar
blaazer2
DONT SKIM IT UNLESS IT IS ABSOLUTELY NECCESARY
Old Sep 12, 2004 | 10:06 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
I can vouch for this, works 100% and helps when you're holding on to the head at arms length.
I took mine off with all manifolds and turbo attached, make sure you have somewhere near by to put it on and nothing in your way cos it's b***** heavy. You won't want to parade around your workshop with it in your arms... However much you love it
Wouldn't recommend trying to put it back on with all manifolds unless you have someone to help, the head + manifolds are proper heavy.
But putting the manifolds back on while the head is on the block is a fiddly nightmare at best.
You make your choices - happy to help if you need a hand.
Old Sep 12, 2004 | 10:20 PM
Eagle's Avatar
Eagle
Super Moderator
cool cheers mate.. still not got round to doing it... need to get it sorted tho .. now got a spark plug problem ... i cant get one out
Old Sep 12, 2004 | 10:24 PM
frog's Avatar
frog
How long is it since you changed them ? They haven't gone rusty on you have they
Old Sep 12, 2004 | 10:26 PM
Eagle's Avatar
Eagle
Super Moderator
erm... july at combe ... thats when we realised it might be stuck ... then tried after national day ... and it aint gonna come out easy like
Old Sep 13, 2004 | 12:43 PM
Stu @ M Developments's Avatar
PassionFords Creator
Pete,
Only tip you need is "Cleanliness pays"
And oil the underside of the bolt heads before torquing with a decent wrench to teh correct figure and no "Bit Extra for good measure" As that fooks em
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
pie-face
Sep 15, 2015 10:43 AM
Chopshop85
Sep 12, 2015 06:42 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
