Excess Pressure in water system!!!!!!
Old Jul 14, 2004 | 09:23 PM
kjc300's Avatar
kjc300
Default Excess Pressure in water system!!!!!!
Apart from the head gasket, and maybe a cracked head/bore, is there anything else that could cause my water system to be pressurised excessively??? i.e blowing it out of the prv on my 20 psi header tank cap!!!
It's coopers ringed by the way, which is why I'm cryin!!!
Old Jul 14, 2004 | 10:16 PM
kjc300's Avatar
kjc300
up
Old Jul 15, 2004 | 01:34 AM
richm's Avatar
richm
sounds like mine at Combe last weekend Kev.... and I haven't found any other reason..
Old Jul 15, 2004 | 11:37 AM
kjc300's Avatar
kjc300
Old Jul 15, 2004 | 02:09 PM
wimwerf's Avatar
wimwerf
your cooper rings are very good but not holy...you know what I mean. I've had the same problem and it turns out it was the head gasket. I think you're car is leaking pressurised gasses through the cooling. I've had it to and I spoiled a new plastic tank in a week.
good luck finding.
Old Jul 15, 2004 | 02:12 PM
Nick500's Avatar
Nick500
Kev by any chance is the cap old? they can sometimes start leaking past a worn cap, I have had that myself as well! But otherthan that I dont thin it will be good news!
Nick
Old Jul 15, 2004 | 03:43 PM
kjc300's Avatar
kjc300
nick, no I tried a 15 psi one first, then the 20 that's on there now!! oh well!! onwards and upwards!!
Old Jul 15, 2004 | 03:53 PM
Azrael's Avatar
Azrael
It ca also be failed fan/fan electrics. Friend of mine had that in his Escos.
Old Sep 12, 2004 | 10:26 PM
blaazer2's Avatar
blaazer2
IF IT IS OVER HEATING IT WILL PRESSURISE [WATER GETS TOO HOT ...WATER TURNS TO STEAM...HEY PRESTO LOADS O PRESSURE] IT MAY NOT BE THE HEAD GASKET IT COULD HAVE A COOLING PROBLEM!!!
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
