boost and mixture
Old Dec 21, 2005 | 08:56 PM
filthyrichie's Avatar
filthyrichie
Default boost and mixture
can anybody give me some idea of standard boost and co% levels at idle and i.e 3500 rpm on 2wd sapp standard set p but i think it has a collins chip!!! thanks
Old Dec 25, 2005 | 06:19 PM
Fiecos Dan's Avatar
Fiecos Dan
you will be seein vacum at idle, and best idle be around 05-2 % CO.
and if map right / set up well, bein seein 0.5 - 1 % CO at 3500rpm.
or are you talkin about full throttle @ 3500 rpm, as that should be around 10psi and 12.0- 12.4:1 AFR, dont know wot that is in CO, but guess around 7-9%.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
