cvh efi prob, juddering when warm,help please!!
Old Nov 30, 2003 | 08:07 PM
The Youth.'s Avatar
The Youth.
Default cvh efi prob, juddering when warm,help please!!
my daily runabout orion 1.6 cvh efi is fine when cold but when it warms up it is lumpy as hell on light throttle, I have changed the map sensor, plugs, iscv with no joy
does the ecu get a signal from somewhere to say what the engine temp is (like a cossie) if so where is it cos I can't find it!!
if it's not that then what else can it be, it's doing my head in!!
cheers,
steve
Old Nov 30, 2003 | 08:33 PM
Stu @ M Developments's Avatar
PassionFords Creator
Throttle position sensor or coolant sensor steve..
Old Nov 30, 2003 | 10:07 PM
The Youth.'s Avatar
The Youth.
stu, changed the tps, no difference, although knowing my luck both would be faulty!
where the heck is the coolant temp sensor, or does it utilise the gauge one?
the gauge struggles to get out of the lower 1/4 so if it is the same sensor then bingo!!
cheers,
steve
ps stu, it's about time I made a donation, how?
Old Dec 1, 2003 | 07:23 AM
JesseT's Avatar
JesseT
It's under the inlet manifold and should be around 20-30 kOhm (anyhow the same as the inlet air temperature) in room temperature. It's in a difficult place to get to, but it can be measured from the large connector next to the fuel regulator.
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
martynhomer01
14
Sep 23, 2015 12:23 AM
RSmark84
Sep 13, 2015 01:29 PM
