Escort Cosworth Front Diff
Old Dec 21, 2005 | 10:18 AM
S1rst's Avatar
S1rst
Default Escort Cosworth Front Diff
Hi, is the front diff where the drivers side drive shaft goes into???
What oil do I need for this, will normal ford oil do the job??
I assume I fill it using the hole in the side until it comes out???
And should ther be a gasket for the bottom plate or do is just use gasket sealer?
Sorry the the silly questions, as you can tell, I have limited knowledge on cosworths!
Cheers, Rich.
Old Dec 21, 2005 | 01:07 PM
Dave Henshall's Avatar
Dave Henshall
it takes 1 litre, use some decent fully synthetic oil like castrol taf-X, 75W90.
remove the small bolts from teh bottom to drop teh plate off and the oil, clean teh faces and then refit with a small bead of silicone sealant , refill as u say though teh filler plug in the side....
Old Dec 21, 2005 | 01:18 PM
GAZ345's Avatar
GAZ345
DIFF ON FRONT O/S OF ENGINE
AS ABOVE SAE 90 HYPOID OIL
IF YOU GET IT FROM FORD=SQM-2C9002-A
TAKES 1LTR
NO GASKET ON DIFF JUST SEALER
SAME AGIN IF YOU GET IT FROM FORD =SAM-1C9111-A
Old Dec 21, 2005 | 02:59 PM
S1rst's Avatar
S1rst
Ok cheers for that guys.
Old Dec 21, 2005 | 04:00 PM
Dave Henshall
1 thing i would say is that as it is so slode to the heat of teh turbo, engine and downpipe, it is well worth trating it to some better oil than normla mineral gear oil, u'll probably find it stinks of smokey bacon in there when u drop it as it will have been baked to death
Old Dec 25, 2005 | 09:20 PM
S1rst's Avatar
S1rst
Ok thanks for that guys.
Old Dec 29, 2005 | 10:23 AM
S1rst's Avatar
S1rst
Just got a price for the diff oil and Ford say you cant buy it in 1 litre tubs, only 5 or 20lts!?!?!
This seems a bit strange to me??? Why would someone want 5 or 20 lts??
Old Dec 29, 2005 | 12:00 PM
Dave Henshall
dont buy it from ford - !!!!
http://www.castrol.com/castrol/secti...tentId=7002854
James Porter
Aug 26, 2015 10:51 PM
Old ford
Jul 31, 2015 06:50 AM
