Zetec into Fiesta?
Old Dec 17, 2005 | 11:25 AM
nathankershaw's Avatar
nathankershaw
Default Zetec into Fiesta?
Will a normally 2.0 zetec out of a Mondeo go into a mk3 Fiesta 1.4i L(single point inj, grey import)?
Is it a bolt in or is there any cutting?
Do you swap the engine and gearbox or use the Fiesta g/box and driveshafts?
Are there any companies that make a wiring loom for the conversion?
Is the exhaust system a custom item or can that be bought?
Thanks for any help.
Old Dec 19, 2005 | 06:15 PM
rodney's Avatar
rodney
you will need the engine loom , sump , pick up pipe , flywheel and clutch , water pump , inlet and exhaust manifolds and engine mounts from a 16v 2i,.
Old Jan 19, 2006 | 06:39 PM
16vzetec's Avatar
16vzetec
your best bet is to buy a 1.8 xr2i crashed and swap the lot onto a 2.0l block
Old Jan 19, 2006 | 07:07 PM
cocaina_xr2i's Avatar
cocaina_xr2i
wrench it all
truth I totally agrre you are better of having the 16v 2i but if you have to monde as a donor then you can doi that way. ether way it would be a great project.
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
Marv888
Sep 26, 2015 03:44 PM
