Intermittent starting. ERST
Old Dec 8, 2005 | 08:58 AM
Chewit's Avatar
Chewit
Default Intermittent starting. ERST
The car starts fine normally just takes a little time to actually fire, just cranks over for a bit. The other week it wouldn't fire. I changed the plugs as they looked old, and checked for a spark, they all worked but still no start. I pulled the fuel pump fuse out and ran it dry incase it had flooded and then put it back in but still no start. Went back to the car about an hour later and it started on the button with the pedal on the floor. This morning it wont start again jus cranks over (still has spark and fuel). The cold start is connected, could this be causing the problem by putting too much petrol in? Bcos it stinks out of the exhaust when it doesn't fire and i think the car over fuels when its running.
Old Dec 10, 2005 | 10:41 PM
CARL B RST's Avatar
CARL B RST
Mine used to flood when it was warm and you tried to start it (after it was stage 1'd about 4 years ago), so we disconnected the cold start and it cured the problem.
Could be worth trying, for how long it takes.
Sadly, now having more warm start problems, which we think is down to the fuel pump - starts fine when its cold though.
Old Dec 11, 2005 | 08:00 AM
HORNETS7's Avatar
HORNETS7
go and have it rolling road tuned m8 it will cure the problem!
DanDMC
33
Oct 7, 2015 01:58 PM
Mc5506
Oct 5, 2015 09:57 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
Rammer46
Sep 18, 2015 08:31 AM
