drive shaft on zetec
Old Nov 20, 2005 | 07:03 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default drive shaft on zetec
ello again my o/s drive shaft dose not look as if its going right in to the box we tried it were we thought it clipted in but no,half an hour later it popted out again,took shaft out cleaned all splines they look ok condition as dose inside the box
ANY 1 ELSE HAD THIS OR CAN SOME 1 TELL ME THE CORRECT WAY TO DO IT
Old Nov 20, 2005 | 09:20 PM
grease monkey's Avatar
grease monkey
why did you have the shaft out in the first place .
they can be difficult to get in some times they do need a good push . some brute force and ignorance as they say.
Old Nov 21, 2005 | 03:59 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
had the shaft out so i could turbo the engine dropted engine and box together can they b quite hard to go bk in i have tried a big plastic hammer and every thing ,i take it its just trying to get past spring clip?
just didnt want to put too much force down it incase i damaged it
BUT WILL IT DEF GO BK IN ???????????????????????????????
THANKS FOR THE ADVICE
Old Nov 21, 2005 | 07:46 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
is there any other probs that could stopp it,feels like its a no go HELP
Old Nov 23, 2005 | 01:36 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
what gearbox is it mate?
the RS2000 has a 25 splines on the inner shafts and the std IB5 ones have 23 splines.
if your using the same g/b and d/s that were on the car originally then just line it so yu can turn the hub, and the g/b turns then give it a whack
Old Nov 23, 2005 | 03:14 PM
16vzetec's Avatar
16vzetec
either wrong shafts or not going in properly.
i usually just put them in then just kick the wheel inwards and they usually just pop in.
you will need the bottom ball joint out to get it in properly
Old Nov 23, 2005 | 05:03 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
GOT IT THANKS GUYS KUST NEEDED SHOWN THE WAY HOME
JK12
33
Apr 26, 2021 12:09 PM
Kam B
Sep 24, 2015 10:40 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
little bram
Sep 7, 2015 11:59 AM
rsstav
Sep 7, 2015 04:43 AM
