rs turbo cooling problems
Old Nov 18, 2005 | 10:28 PM
yzfr1boy's Avatar
yzfr1boy
Default rs turbo cooling problems
hi can any one help me please my 88 rs turbo the temp gauge reads up on the high side but not in the red !above the n, the fan cuts in and it does not boil over and when you idle the heater in the car goes cold until you hit 3000 rpm then its hot again ,i have tried a new thermostate n sensor but the gauge is still high and the bloody heater is crap any help muchly apreciated as im new to rs turbos thanks
Old Nov 19, 2005 | 06:56 AM
HORNETS7's Avatar
HORNETS7
hmm seen as though its speed that makes your heater warm i would say uve got a knackered water pump!
as your making it work harder to push the water round @ 3000rpm
also check you have got a thermostat in now as winters here it will need one!
this will also remove any airlocks u might have too!
Old Nov 22, 2005 | 10:46 PM
yzfr1boy's Avatar
yzfr1boy
yer tried the new pump on saterday and to no avail the car is exactly the same but did find a hair line crack in the engine block at the front behind turbo its not pouring out but there is a bit dampness there ,it has had new thermostate n sensor fitted ,please help you guys cheers
Old Nov 22, 2005 | 11:34 PM
SafeChav's Avatar
SafeChav
cracked block?
thats only going to be the start of the problems, no doubt something else is up aswell but its pointless trying to repair it with a cracked block, the block is going to do nothing else other than get worse
sorry to have to say it
Old Nov 23, 2005 | 07:40 PM
HORNETS7's Avatar
HORNETS7
COULD BE A AIR LOCK BUT THE CRACKED BLOCK AINT GOOD NEWS!
Old Nov 29, 2005 | 12:32 AM
yzfr1boy's Avatar
yzfr1boy
yer the block upon inspection has a 6inch crack so bought new motor outa 60k car which had the head overhauled for 200 quid last nite so well see how this one is will keep you posted cheers bri
Old Feb 8, 2006 | 01:09 AM
yzfr1boy's Avatar
yzfr1boy
new motor fitted now alls well for the min lol
Old Feb 8, 2006 | 01:11 AM
SafeChav's Avatar
SafeChav
Billy_RS
16
Oct 11, 2025 09:41 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
