losing oil pressure when engine warms up ?
Old Nov 10, 2005 | 07:55 PM
shaunt's Avatar
shaunt
Default losing oil pressure when engine warms up ?
i just changed the crank in my rst i had it polished and measured it was standard so i used all new bearings new oil pump now when it starts up it got good oil pressure but seems to loose it after about 5 mins even though the engine doesnt rattle the gauge reads 0 and oil light comes on ,on tick over and goes off when i rev it over 2 grand . can anyone help ?
Old Nov 10, 2005 | 10:59 PM
320 bhp's Avatar
320 bhp
HAD SAME PROBLEM CHANGED OIL PRESSURE SWITCH AND IT SORTED IT,IF U TAKE OIL FEED PIPE OF TURBO AND TURN IT OVER U WILL SEE IF YA HAVE GOOD OIL PRESSURE GOOD LUCK
Old Nov 11, 2005 | 05:02 PM
shaunt's Avatar
shaunt
just tryd a new switch and it still the same i just found out off the previous owner it did it on him so he took the bulb out but now i changed all crank and bearings i cant understand why it does it i have got oil pumping from oil feed but gauge still drops to 0 as it wams up and light comes on on tick over ? its strange ???
Old Nov 11, 2005 | 06:43 PM
Alvyn's Avatar
Alvyn
try a different grade/make of oil and go from there
Old Nov 13, 2005 | 12:00 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
if the oil is too thin when hot their will be low pressure.
remember oil goes thinner when hot, so theirfore will have less pressure than when its cold (thick).
sounds weird it goes to zero tho
Old Nov 13, 2005 | 04:23 PM
shaunt's Avatar
shaunt
i been putting 10 40 s oil in i thought that would be ok i noi tryed 2 diferent gauges in case 1 was faulty i cant beleive it reads 0 but the engine runs quiet and doesnt rattle or tap ? thanks anyway for all the help ....
Old Nov 14, 2005 | 10:50 PM
xrsi's Avatar
xrsi
been told that 10-40 is too thin for an rs turbo!
try something like 10-60 castrol RS or mobile stuff!
Old Nov 15, 2005 | 09:03 PM
shaunt's Avatar
shaunt
ok cheers will get some and change it at weekend thanks for that ....
Old Nov 16, 2005 | 07:02 AM
HORNETS7's Avatar
HORNETS7
sorry to have to tell u this but i reckon its the bearings still !
i had this problem before and it was because of the wrong size shells!!
Old Nov 16, 2005 | 05:01 PM
shaunt's Avatar
shaunt
to be honest thats what i have thought all along but i just wanted seee if there was anything else. i am going take the crank back out and take it to another engineers see what they say about its size the 1 who did measure it told me it was standard sizes . thanks for that ..............
Chas
Sep 21, 2015 08:57 PM
Adam-M
Aug 26, 2015 05:53 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
mrmann
Aug 20, 2015 11:24 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
