ring gap question
Old Nov 8, 2005 | 09:10 AM
16vzetec's Avatar
16vzetec
Default ring gap question
ive got a 2.0l zetec.
its been rebored and has +.50 pistons.
ive checked the ring gaps and they are too big according to the haynes manual.
it says 0.30 to 0.55 mm.
my ring gaps are 1.00mm.
this would suggest the bore is very slightly too big.
but what effects would this have on the running of the engine if any??
Old Nov 8, 2005 | 07:25 PM
abdr500's Avatar
abdr500
did you get over size rings to
Old Nov 9, 2005 | 03:06 PM
fightingtorque's Avatar
fightingtorque
i am assuming you are talking about building up an engine with new parts here, if it's something you just stripped then the simple answer is that the rings are worn.
since you mention haynes manual, i presume you are aligning the rings by pushing them in with a piston as they usually describe? if they aren't in straight you'll get a big reading.
1mm is too big and will give excessive blow by.
did the rings and pistons come from the same source? sometimes the tolerances on aftermarket pistons are a bit ropey, and the recon guys tend to bore to the piston size as it's easier for them to measure clearances than accurately measure the bore size. gives a good fit between piston and bore but if the ring comes from someone else......
having said all that, controlling the ring gap tolerance is not normally too difficult, hence the first question about the measurement.
Nov 1, 2015 06:53 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
deathrider666
Sep 28, 2015 06:12 PM
