Replacing zetec pistons
Old Nov 7, 2005 | 10:42 AM
demolition_man's Avatar
demolition_man
Default Replacing zetec pistons
Hi, i have damaged a piston and rod from my 2.0 zetec, can i simply swap all 4 for another set? or will i have to get 1 and have it machined to suit? Thanks a lot, Aid
Old Nov 7, 2005 | 04:04 PM
Red16's Avatar
Red16
be best of changing the 4 pistons and sticking a set of new rings on them while theyre out the engine.
how have you damaged the piston & rod?
is the bore damaged?
Old Nov 8, 2005 | 04:22 PM
demolition_man
thanks for reply mate, the bore is fine, i just fubard the bottom of the conrod as when i came to undo the rod bolts one was seized and i mean REALLY seized. So after i had broken a few tools on it and completely chewed up the head of the bolt, i took an angle grinder to it. A move i now regret as i managed to take a mm or two of mating surface off the conrod. bugger. Never mind, thats what u get for employing cowboy tactics.
Should be able to source a new set of pistons and rods for cheap enough anyway, will be easier than getting 1 balanced etc.
Aid
Old Nov 8, 2005 | 05:01 PM
Red16's Avatar
Red16
i got a set in my zetec engine if you fancy them? theyre surplus to requirements as im going steel rods and forged pistons
Old Nov 9, 2005 | 03:35 PM
demolition_man
cool pm me a price, i'm interested in them thanks
Old Nov 10, 2005 | 05:26 AM
fightingtorque's Avatar
fightingtorque
probably best to 'glazebust' the bores - think any haynes manual covers this.
trust the bores aren't too worn. the thing that can be a problem is that if you have a lip at the top where the original top ring was at TDC, then if your new rod/piston combo puts the rings a little higher owing to manufacturing tolerances, then the new ring will hit the step and get damaged.
this problem can also happen with rod stretch, for example you buy a car off your granny/ sister whoever that has never been run past about 3k, and first thing you do is take it to 7k. the extra revs stretches everything past where they took it and you hit the ridge.
fortunately my granny doesn't drive any more (just as well) and when my sister isn't looking i make a point of taking her car out and thrashing the living daylights out of it just to prevent this problem.
jessie_rs
62
Aug 6, 2019 09:27 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
grishenko45
Sep 9, 2015 12:58 PM
ajamesc
Sep 8, 2015 06:51 PM
BRAM
Sep 8, 2015 07:11 AM
