Focus ECU problems
Old Nov 1, 2005 | 02:11 PM
ANDYWEIGHTMAN's Avatar
ANDYWEIGHTMAN
Default Focus ECU problems
My Ford Focus, 1.6 Zetec, 2000 plate, has a misfire problem. Two cylinders aren’t running with spark plugs 1&4 not firing. I have changed the Coil Pack and checked the wiring to the ECU.
Has anyone else had this problem?
Is it the ECU and do you know if it is repairable?
Old Nov 2, 2005 | 07:37 PM
Dan martin's Avatar
Dan martin
hi mate sounds like the coil pack had gone down and has spiked your module, with the ignition on you should have battery voltage in the middle pin of the coil pack multi plug and a switched earth at the other two pins one side will fire 1&4 and the other side will fire 2&3, you can check the earth is being sent by the module by using a side light bulb, if it flashes one side and not the other then as long as the wiring to the module is ok it the module itself. hope this helps.
Old Nov 4, 2005 | 01:03 PM
ANDYWEIGHTMAN
Cheers for the info. Tried it and I'm now sure it's the module. The ECU has a 4 letter code which is PAID. Been trying to find an ECU with the same lettering and a chip from the key fob so I don't have to get the ECU decoded. Do you know if I can fit an ECU with a different code as so far I can only get one for same year and 1.6 with key fob chip but the code is JUDO! This must be wired differently but will it work on my car?
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
