Changing valve stem oil seals
Old Oct 30, 2005 | 03:49 PM
haz87's Avatar
haz87
Default Changing valve stem oil seals
On a cvh, how do you do it? Obviously rocker cover off, then.....
Old Oct 30, 2005 | 04:12 PM
antony215's Avatar
antony215
Escort Rs Turbo
undo the 13ml bolt's on the rockers (one at a time as you go) take the rocker off then you need to compress the spring and take the two little colicks from the valve head then take the spring off and you will see the valve stem seal just pull it off how are you doing it are you taking the head off or doing them with the head on???
Old Oct 30, 2005 | 04:16 PM
haz87's Avatar
haz87
head on if possible
Old Oct 30, 2005 | 04:21 PM
antony215's Avatar
antony215
Escort Rs Turbo
you want one of these then
Ł10 plus p+p from www.burtonpower.com
Old Oct 30, 2005 | 04:23 PM
haz87's Avatar
haz87
and that does what exactly
edit: doesnt matter, checked on burton,lol.
Do i need to have the cylinder at tdc when doing the relevant valve?
Old Oct 30, 2005 | 04:28 PM
antony215's Avatar
antony215
Escort Rs Turbo
you put it on where the rocker was and it compress's the valve spring when you tighten the nut down on it so you can take the two little collicks out from the valve head other wise it's a socket and a hammer (which i would'nt do )
Old Oct 30, 2005 | 04:35 PM
antony215's Avatar
antony215
Escort Rs Turbo
you do have to have the piston's up so the valve dont fall in the pot best way to check is to take the plugs out and put a screw driver down and make sure the piston is right up it duz tell you how to do it in the instructions when you get the tool
Old Oct 30, 2005 | 04:36 PM
haz87's Avatar
haz87
cheers mate, doesnt sound too bad, thanks for the info
Old Oct 30, 2005 | 04:39 PM
antony215's Avatar
antony215
Escort Rs Turbo
No problem mate it's not that hard if your handy with the spanner's should take you about an hour.
Sheepdisease
Aug 30, 2015 09:11 PM
YODI
Aug 30, 2015 01:12 PM
Danielbetty
Aug 28, 2015 08:01 PM
cameron2
Aug 25, 2015 07:18 AM
st220kyle
16
Aug 14, 2015 06:13 AM
