stage 3 cossie setup question
Old Oct 26, 2005 | 12:42 PM
RScrew69's Avatar
RScrew69
Default stage 3 cossie setup question
Is it possible to run a stage 3 saph setup without the 3 bar map sensor and just the standard 2 bar? or is it a must and needs to be fitted for the car to run correctly?
cheers folks
Old Oct 26, 2005 | 02:01 PM
davidreader5's Avatar
davidreader5
HI,
If it is a stage 3, 803'S ETC, with approx 23psi boost you can't use the 2,bar map
sensor as the fuelling info etc will NOT match the chip,
DAVE R.
Old Oct 26, 2005 | 02:04 PM
cossy abuser's Avatar
cossy abuser
3 Bar map sensor work minus one Bar, plus two Bar, so it will work upto 29.4 psi boost
2 Bar works with one Bar minus and plus from zero, thats why a stage one running 15psi works on a standard map sensor
Old Oct 26, 2005 | 02:10 PM
RScrew69's Avatar
RScrew69
ok if i set it up for 18psi for the time being on a stage 3 setup would that be ok? or not really and recommend a 3 bar map sensor?
cheers
Old Oct 26, 2005 | 02:13 PM
cossy abuser
will be ok as the Map sensor will only show 18psi to the ECU so fueling will\should compensate for it
I have a few 3 Bar sensors at 45 quid posted
Old Oct 26, 2005 | 02:16 PM
davidreader5
HI,
IMO, the fuelling etc will still not be100%, correct for the chip
who you had the chip off they will know for certain, but rather
than say yes in theory, could be a expensive mistake, just
buy another 3,bar sensor,
DAV R
Old Oct 26, 2005 | 02:21 PM
RScrew69's Avatar
RScrew69
thats what i'm going to do now after thinking about it. Whats the correct part number that should be printed across the 3 bar map sensor?
cheers again peeps
Dave Henshall's Avatar
Dave Henshall
you should only ever use the correct sensors/injectors chip combination, unless u want a bwokenised engine, they are unreliable enough as it is without giving them a helping hand
cossy abuser
If you are only running a 2 Bar with 803's at 18psi, the only problem you will have is slight over fuelling which will be safer than underfuelling.
Old Oct 26, 2005 | 02:22 PM
Dave Henshall
2 bar - APS02/03
3 bar - APS05/01
Old Oct 26, 2005 | 02:24 PM
RScrew69's Avatar
RScrew69
ok so thinking about it, whats a nice sensible and safe power setup and boost level with greens, 3bar and stage 3 chip ? to use on an everyday car?
Or should i say what will the stage 3 setup be happy with 20psi?
cheers
Old Oct 26, 2005 | 02:25 PM
RScrew69's Avatar
RScrew69
i got a msd evo chip aswell if this helps
Old Oct 26, 2005 | 02:27 PM
cossy abuser
Ask Stu to be sure then
Old Oct 26, 2005 | 03:05 PM
Dave Henshall
there should be a serial number on teh sticker on teh chip, stu can match that to his records and tellu exactly what the spec of th chip is,
u cant really say all atg 3 are 22 psi say,,, some are 22, some are 25, mine is 29 peak and then backs off to a held 25, but that is cos the chip is mapped for that and it has had the full setup and been checked through the boost and revs on teh road by stu to make sure its all good,
i'd say for the sake of 100 quid to have stu give it the once over, its well worht it as any problems that u may not even be aware of may become aparent that could cost big money if not tended to early before it goes bang
Old Oct 26, 2005 | 03:57 PM
cossiegreg1's Avatar
cossiegreg1
mine was running approx 23psi ran mint but i have a wrc steel head gasket .I was told not to go over 19psi with original head gasket is that correct?? ihave just turned boost down to 18psi as its bad weather time and the car will be going to bed soon for winter
JK12
33
Apr 26, 2021 12:09 PM
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
truffleshuffle
Sep 10, 2015 09:35 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
