fueling 2wd
Old Oct 25, 2005 | 10:04 PM
cossied's Avatar
cossied
Default fueling 2wd
When I bought my car it was 347 bhp running 3 bar map sensor dark greens I rebuilt the engine and used Stage 1 chip, 2 bar map sensor and dark blue injectors, would the fuel pressure have been turned up and do I need to turn it back down, it is not very good on fuel even on a motorway run and the exhaust is very dark on the MOT it is well within the spec for CO. thanks
Old Oct 25, 2005 | 11:50 PM
davidreader5's Avatar
davidreader5
HI,
just set the fuel pressure for what the stage one chip
should be, ask the company who supplied it, most just use the std
fuel pressure but different co% value, std cosworth weber marelli
fuel pressure is 3,bar @ idle 3.5bar with vacuum pipe off,
DAVE R
Old Oct 26, 2005 | 07:52 PM
cossied's Avatar
cossied
Default fuel
Thanks for that Dave I can now see that someone has put a small bolt in the reg hole. I think the screw adj underneath is screw in for more pressure out for less. thanks ED
Originally Posted by davidreader5
HI,
DAVE R
Old Oct 26, 2005 | 08:11 PM
davidreader5
ED,
Yes it is adjustable usually allen key
DAVE R
Old Oct 27, 2005 | 07:01 PM
cossied's Avatar
cossied
Default fuel
can anyone tell me where you measure the fuel pressure. thanks
Old Oct 27, 2005 | 08:33 PM
davidreader5
ED,
scan for you,
DAVE R.
JK12
33
Apr 26, 2021 12:09 PM
3doorcozmess
Sep 15, 2015 06:06 PM
dojj
28
Sep 11, 2015 10:00 PM
rsstav
Sep 7, 2015 04:43 AM
jc1989rs
Sep 5, 2015 08:09 PM
