Converting an MFI to EFI, slight problem please help!!
Old Oct 25, 2005 | 08:31 PM
SafeChav's Avatar
SafeChav
Default Converting an MFI to EFI, slight problem please help!!
Ok, got all the stuff i need to convert my MFI turbo to EFI, one slight problem.....NO HOLE FOR THE CTS SENSOR. Obviously because its an escort block, but one of you brain boxes out there must know somewhere else u can mount the sensor or a way of getting around it??
help me out and make me happy
Old Oct 25, 2005 | 09:12 PM
P_is_for_Paul's Avatar
P_is_for_Paul
Coldo loves seamen
http://www.rsbible.co.uk/
It tells you on there just to drill a hole-
"The Fiesta RS also benefits from having the hole drilled in the block, to allow for the CPS. Rumour has it that late 'H' plate S2's also came with this block, so this could be used. The other option is to drill the hole yourself, which would not be overly difficult, just ensure that you get it in the right place"
Feelin Confident?
Old Oct 25, 2005 | 09:14 PM
SafeChav's Avatar
SafeChav
i was hoping someone wouldnt be that clever n suggest drilling a hole
there has to be another way??
don't think what u said isnt appreciated though just no.....not feelin overly confident, dont like making holes
Old Oct 25, 2005 | 09:17 PM
P_is_for_Paul
Coldo loves seamen
Im with you mate, I wouldnt attempt it either!
Try JanoOddkidd he seems quite helpful
Old Oct 25, 2005 | 09:23 PM
davidreader5's Avatar
davidreader5
HI,
are you using a efi manifold from a fiesta etc, i drilled and tapped
a whole where on the RS TURBO manifold escort, the cts would be
i used a fiesta or escort efi manifold for cosworth conversion,
will if i have time post up a diagram.
ok seen your mistake.
Dave R.
Old Oct 25, 2005 | 09:30 PM
SafeChav's Avatar
SafeChav
hello there mate
thanks for the reply, my fault however, i meant CPS (crank position sensor) not the coolant temp sensor sorry.....my mistake
Old Oct 25, 2005 | 09:42 PM
JesseT's Avatar
JesseT
It's just a hole for fucks sake. Just drill it.
Old Oct 25, 2005 | 09:45 PM
SafeChav's Avatar
SafeChav
and if i fuck it up.....?
Old Oct 26, 2005 | 12:25 PM
sailorbob's Avatar
sailorbob
An alternative is to fit an aftermarket crank trigger wheel to the front pulley, Omex do a couple for about Ł30.
Old Oct 26, 2005 | 04:57 PM
Moonie's Avatar
Moonie
If you decide to drill it you will have to be accurate with the position otherwise TDC detection wil be out and therfore timing. I have a late 89 spec Escort turbo and it has the hole in the block for the sensor.
Have you considered mounting an aftermarket trigger wheel on the front pully or using a pully and position sensor off a cvh sierra?
Old Oct 26, 2005 | 06:32 PM
SafeChav's Avatar
SafeChav
i have seen sierra's at the local scrappy with the wheels on, and the thought crossed my mind but they have the grooved belts so i didnt think i could use one.
Has this been done before then has it?
Does the timing wheel seperate from the pulley?
cheers
Old Oct 26, 2005 | 08:47 PM
runty176's Avatar
runty176
you cant just drill the hole in the block coz you need the trigger on the fly wheel as well .
best way is to find an aftermarket sensor and trigger that mounts to the front crank pulley .
or drop the engine and use an e.f.i block .
sorry .
Old Oct 27, 2005 | 08:17 AM
JesseT's Avatar
JesseT
He said he has everything needed.
Seriously I can't always understand you British. No offense, but all this moaning over drilling a hole. Even block swap suggested instead
If you don't feel confident on your drilling skills (pressing the trigger...), then pay a fiver for someone to do it for you. Better do it properly and not mess with triger setups in the timing end of the engine.
Old Oct 27, 2005 | 05:15 PM
SafeChav's Avatar
SafeChav
i do have everything i need........so whats the point?
swings and roundabouts, cant understand u foreigners either, not into BODGING stuff up thanks.
Yeah.....CHANGE THE BLOCK, sounds like a good idea, considering ive just dropped the re-built engine in 3.5k ago
NICE ONE MATE glad u were here to help Don't know what i would of done without your life saving suggestion and criticism
If any can genuinely thinks they can help then its much appreciated.....don't waste your breath if you're going to criticise
Old Oct 27, 2005 | 08:20 PM
runty176's Avatar
runty176
no criticsm intended !!!!
i have had to drill one before .
i made a template from a scrap block with crank hole .
then removed flywheel and marked where hole needs to be drilled . then drill hole from g/box side (it is nice, flat surface this side)
it is quite a big hole coz the crank sensor fits in a round plastic holder which i secured from flywheel side as well.
Dont forget to fit the other flywheel as well coz it has cut outs that trigger the crank sensor .
it really isnt a nice job to do , and i was lucky to have a scrap block with the sensor hole as a reference .unfortunately i binned the template.
are you sure you want to go to e.f.i.
i know its not nice to here , but i am on your side
Old Oct 27, 2005 | 08:26 PM
SafeChav's Avatar
SafeChav
see thats part of the problem i slugged my guts putting engine in and ill be damned if that engine/gearbox/both are coming back out anytime soon!
I know what you are saying about making it as it should be, but not very productive in my case.
yeah im definately sure, im sick to death of SH1TTY KE JETRONIC and all the air leak and running problems associated with it!!!
and the other reason....i want wastegate flutter
Old Oct 27, 2005 | 08:45 PM
runty176's Avatar
runty176
have a look at an 1800 cvh from a sierra to see if the pick up is on the crank pulley . if it is that should be quite straight forward to convert .
a pinto/cossie pulley has notches sticking out of it so isn't seperate . the pulley wouldn't fit on the crank.it would be also quite difficult to set the right air gap on the sensor to the pulley , and getting it in the right place could be tricky .you dont want reliabilitie to be an issue . the spark has to be spot on . one degree the wrong side and running problems may occur .
WEBCON . make management bits and pieces . mainly for zetec converted caterhams . Last time i spoke to them they did make aftermarket crank pick ups for crank pulleys . if you like i can see if i still have thir number when i get to work tomorrow.
i think an aftermarket kit may be the way to go if you dont fancy dropping the engine down again
Old Oct 27, 2005 | 08:46 PM
davidreader5
HI,
Only way your going to get a efi setup, is to have a disc and sensor
setup from the crank pulley, some after market ecu's can use your origonaldistributor, but if your putting either cossie, or fiesta turbo, you have to run a disc as already said or use the fiesta flywheel idea,
i had my own design made by a engineering company, at the end of the day, you have to simulate the system you intend to fit in theory,
what management are you trying to fit,
DAVE R.
Old Oct 27, 2005 | 11:03 PM
SafeChav's Avatar
SafeChav
just upgrading to fiesta management.
i checked out the wheels omex do (only up the road ) they do a 36-1 wheel, shold be able to mount that on the pulley. Same number of teeth as the flywheel, so all should be good!
Old Oct 28, 2005 | 09:08 PM
davidreader5
HI,
Just make sure it is mounted to the pulley in the correct position
for timing reference,
Dave R,
Old Oct 30, 2005 | 07:23 PM
JesseT's Avatar
JesseT
Originally Posted by davidreader5
HI,
Didn't know that the engine was already in the car. Anyhow, in the 36-1 wheel, the center of the missing tooth should be aligned with the sensor when cylinder #1 is 90 degress BTDC.
Old Oct 31, 2005 | 08:56 PM
SafeChav's Avatar
SafeChav
thanks for the info
Old Jun 14, 2006 | 06:52 AM
Schmidi's Avatar
Schmidi
SafeChav: did you finally finish the conversion?
Did you drill the hole for the CPS, or are you using an aftermarket trigger?
Is the sensor in an aftermarket tirgger kit the same as the OEM one? So if I have one, is it enough to create/buy only the trigger plate?
Old Jun 14, 2006 | 08:19 AM
SafeChav's Avatar
SafeChav
I haven't done it as yet, but i am going to drill the block after all. In a newer thread i started JesseT put up a picture of his block after very successfully drilling it
Old Jun 14, 2006 | 09:11 AM
rst_cabby's Avatar
rst_cabby
I've got a xr3i efi block in the garden if u want me to make up a template for you ...........
Old Jun 14, 2006 | 09:12 AM
SafeChav's Avatar
SafeChav
Was that for me? That would be FUCKING EXCELLENT if you would
Old Jun 14, 2006 | 09:32 AM
rst_cabby's Avatar
rst_cabby
Are you about tomorrow as i'm up that way - can drop it off for you?
Old Jun 14, 2006 | 09:43 AM
SafeChav's Avatar
SafeChav
I will be around tomorrow mate yes
This template, what is it a paper drawing or a metal thing or what?
Thanks very much
Old Jun 14, 2006 | 02:39 PM
rst_cabby's Avatar
rst_cabby
Hi - home now from work - will make it out of cardboard so you can place it against the gearbox side of the block - you can then draw on the exact place to drill - with the template it will make your life alot easier to drill it in the right place - take it u do have a efi flywheel?
Old Jun 14, 2006 | 03:10 PM
SafeChav's Avatar
SafeChav
Indeed i do have a EFI flywheel ready to fit
Old Jun 14, 2006 | 03:43 PM
rst_cabby's Avatar
rst_cabby
PM me your address & i'll see you a.m - probably about 11
xrmalin
Sep 13, 2015 06:52 PM
RSmark84
Sep 13, 2015 01:29 PM
stevierob
Sep 7, 2015 07:09 PM
bigryrs
Sep 7, 2015 06:45 PM
hopper350
Sep 4, 2015 12:53 AM
