Gerbox gone?
Old Oct 19, 2005 | 07:30 AM
sfaki2005's Avatar
sfaki2005
Default Gerbox gone?
Hi everybody, i put in a second hand gearbox in on saturday which came off an F reg escort rs, also put in a new ap competition organic clutch with it, now i have a problem which im hoping its not the box, it keeps jumping out of first gear. everyother gear is perfect, i also replaced the linkage. all the gears go in very smoothly apart from this issue of jumping out of first on take off. what can this be synchro gone or going?? it also doesnt happen all the time, sometimes first gear may stay in? im going crazy thinking about it.
can it be anything elese like linkage adjusting??
i was told it had a LSD, which is the best way to test this?
please advise.
Old Oct 21, 2005 | 02:23 PM
ASHCOSSIE's Avatar
ASHCOSSIE
hi when my box started to go it jumped out of reverse all the time not to sure if yours is doing the same as mine the way i have been told to test if its got a limited slip is by putting car so both front wheels of the ground rotate one wheel and the other should rotate the same way if the other wheel spines back when u spin one forward its not a limited slip
Toms Grende
13
Aug 22, 2015 03:39 PM
marcy
Aug 14, 2012 06:29 PM
