Mondeo Heater Problem
Old Jul 5, 2004 | 01:15 PM
cmd205's Avatar
cmd205
Default Mondeo Heater Problem
Hi there.
The heater in my mondeo has started playing up.
It will blow air when the dial is turned to number 4 but from 1 to 3 there is no output whatsoever.
I have checked the fuses and relay and they all semm fine.
Has anyone got any ideas.
Thanks
Old Jul 5, 2004 | 01:18 PM
Blade's Avatar
Blade
Sounds like the resistor that controls the fan speed. Monnys are well known for melting the electrical plug that goes onto the fan motor, you can find it in the passenger foot well atached to the heater box.
hth
Old Jul 5, 2004 | 07:15 PM
AKRS1's Avatar
AKRS1
I had this problem on my rs turbo and it was the resistor as blade says
Old Jul 5, 2004 | 07:28 PM
GUZZLER's Avatar
GUZZLER
9 times out of ten its the resistor, there only about £10 from fords, although you may need the loom plug that go's onto it. (avalible seperatly)
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Brickhouse
Sep 20, 2015 11:47 AM
Flatlinedan
Sep 18, 2015 12:41 PM
Flateric_2002
Sep 15, 2015 08:41 AM
