undersealing
Old Oct 10, 2005 | 11:00 AM
AdamB's Avatar
AdamB
Default undersealing
quite soon i hope to spend a few days sorting the underside of my fiesta.
i want to get rid of all the rust, and underseal it, but would like it all to remain bodycolour underneath.
how do i go about it, what products should i be using?
i'm guessing i aplly and underseal and then, primer and paint it.
finally seen the light in keeping the bits you dont usually see in good condition.
my car is 7 years old and i'm noticing rust in all sorts or areas.
thanks
Old Oct 11, 2005 | 09:02 AM
AdamB's Avatar
AdamB
anyone?
Old Oct 14, 2005 | 08:46 PM
Moondust_crust's Avatar
Moondust_crust
first what mk of fiesta is it mate, the only real way to do it is to dismantle all the suspension clean it all up either paint it or whateva and wipe some thinners or petrol over the rubberrised underseal ford put on ,
to get all the shite off ,
then as you say primer it all paint it the colour of your car and a good couple of coats of laquer,
while you have got it all apart you could poly bush the whole car , either do the rear end first then work your way to the front, have a look at twins thread on here his underbody resto is amazing, hope this helps. mark.
(ps for fock sake dont just paint hammerite ontop cus it will look shite)
Old Oct 15, 2005 | 06:08 PM
AdamB's Avatar
AdamB
no, dont worry, wont be hammeriting...
its a mk4 fieta, its all ready poly-bushed all round, but may get another rear beam powdercoated and then the bushes swapped across.
so thinners on the crappy standard stuff?
whatr do i use to seal it all before the paint etc goes on? the waxoyl stonechip stuff or sommat else?
Old Oct 15, 2005 | 07:06 PM
Moondust_crust
yeah just wipe it with thinners , its will just get rid of all the muck and grime thats ontop of the standard rubberised ford stuff, no point in taking all the standard ford stuff off its done a good job so far
thats what im having to do with mine and its a pain in the fooking arse.
have a look at this pic.
you could stonechip it all but thats totally up to you, i would just give it a couple of coats of zinc etch primer, couple of coats of body colour then 2 or 3 coats of laquer. sorted.
hope this helps
GAZ345's Avatar
GAZ345
once you get all the old crap off, prime it stone chip it ( not underseal) prime again then paint as normal
Old Oct 16, 2005 | 10:07 AM
AdamB's Avatar
AdamB
cool, cheers, this is the kind of advice i'm after
Old Oct 16, 2005 | 04:38 PM
Red16's Avatar
Red16
is stonechip solid like normal paint is when its gone off or is it kinda rubbery like underseal ?
Old Oct 16, 2005 | 09:44 PM
pugo's Avatar
pugo
stone chip goes hard
and if you buy the right stonechip you do not need to prime you can just paint straight over it in top coat
IainRS1700T
Sep 25, 2015 06:44 AM
smitsturbo
Dec 16, 2006 04:29 PM
shane
Aug 16, 2006 08:44 PM
Nick500
Apr 22, 2005 02:26 PM
Moondust_crust
Oct 29, 2003 09:15 AM
